Axle keeps popping out
Re: Axle keeps popping out
Yeah the axle shaft keeps popping out the transmission. Not sure if it makes a difference that the shaft is from a 1999 civic and my civic is a 1997 but I did notice that the shafts were shapped differently. I will be trying the 1997 shafts to see if it makes a difference. I had one shaft from the 1997 on the passenger side which gives me no problem but the driver side axle which was the 1999 is the one that keeps coming out.
O.G. triple O.G.
raise the car up, secure with jackstands. Go underneath the car and see if you can move the driver's axle (left to right) with your hands. If it moves, replace the axle. You will see it move on the inner boot (near the tranny). More than likely, the knuckle is loose/damaged.
Make sure you're getting it in all the way. They have to be installed with some force. My method is to put the outer end in the knuckle and swing it out to slam the axle in before putting the ball joint back on. (Be careful not to over-extend the inner joint.) The inner joint should end up very close to the transmission and you should not be able to pull it out by hand.
integrainside
Transmission & Drivetrain
10-03-2013 05:21 PM
