Axle Installment Help
I have a quarter inch left to sink into the tranny on a b18b/gsr tranny swap on the passensger side. I'm guessing its the ring clip is the culprit. Do any of you have a trick to getting it to snug down, It seems like with enough umphh it will seat in there. I dunno. These are 96 integra axles that matched the transmission. Any suggestions or techniques would be greatly appreciated. Thanks
Make sure everythings lined up correctly, and if you think its the ring, bring the axle back out, and make sure it isnt bent or mis-shaped. Most ppl are going to tell you to keep trying, which may be the case, sometimes you really gotta man-handle them in place.
Re: Axle Installment Help (elmo908)
put a block of wood against the end of the shaft give it a few light taps with a hammer it will slide into place
alright thanks for the quick replies, I have another set that came with the ls transmission that came on the motor. So perhaps I will pull them out and check it, I don't want to damage the cv at all. Thanks again
Re: Axle Installment Help (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Just smack them in as hard as you can. </TD></TR></TABLE>
Is that safe to do to an axle? lol
dude you shouldn't need to hit it at all but you can usually when they just dont wanna go it its because they're dirty take it out and clean it good i usually just use an air chuck to blow it off really good then boom slides right in and if this still dont work then use a rubber mallet and TAP it a few times
Re: (SkertySkerty)
just hand tighten the axle nut and use the hub as your hammer.. usually you wont need to but ive seen times when you really had to bang that bad boy in there!
Also sometimes if you take the axle back out, and rotate the lock ring a little so it's sitting different, it will slide in, alot of times it just catches a edge or something, so movin it around a little bit helps, again in some cases, it's hard to know what's going on with yours because we are not there, but I would say banging on the end would be saved for desperate measures, I just don't like the idea of hammering on my cv joints. Just my opinion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elmo908 »</TD></TR><TR><TD CLASS="quote">I have a quarter inch left to sink into the tranny on a b18b/gsr tranny swap on the passensger side. I'm guessing its the ring clip is the culprit. Do any of you have a trick to getting it to snug down, It seems like with enough umphh it will seat in there. I dunno. These are 96 integra axles that matched the transmission. Any suggestions or techniques would be greatly appreciated. Thanks </TD></TR></TABLE>
what i usually do when this happens is i lube it up alittle and it slides right in.
Re: Axle Installment Help (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">
Is that safe to do to an axle? lol</TD></TR></TABLE>
Worked for me, no leaks and hasn't popped out since last year.
ok I will pop it and rub it down with some grease give the axle a little rotation and try round 2 right now. So close yet so far. Thanks for the replies and any more insight please feel free to chime in. Thanks.
Re: (elmo908)
lube it up as stated above, while inserting it in the tranny grab the housing that buts up against the tranny, and wiggle and rotate it as you insert the shaft and it should slide in
ok, I went to napa and bought a new axle and gave them a shitty ls abs one that I had lying around extra for the core. Still same dilemma. Ive been putting some muscle into it but it is a funny angle. The axle feels like it is locked in, I have to use a crow bar to pop it out but it still has a little room left to go, the mallet doesn't seem to be helping much, I don't want to bang the boot too hard either. Sorry about the long sentence, so close yet so far.
Re: (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic »</TD></TR><TR><TD CLASS="quote">lube it up as stated above, while inserting it in the tranny grab the housing that buts up against the tranny, and wiggle and rotate it as you insert the shaft and it should slide in</TD></TR></TABLE>
Thats what SHE said!
Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic »</TD></TR><TR><TD CLASS="quote">lube it up as stated above, while inserting it in the tranny grab the housing that buts up against the tranny, and wiggle and rotate it as you insert the shaft and it should slide in</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">
Thats what SHE said!</TD></TR></TABLE>
LOL X2
LOL X2
HGZ
03-08-2005 01:12 AM
