Axle doesn't want to go into hub?
Ok...so as most of you know my driver's side axle was stuck in my old hubs. I got a 5 ton puller and was able to pull it out with little problems. Nothing was damaged...it is just an old car and with a little rust, it got stuck in there.
Now...I am swaping del sol Si brakes on my del sol S. The axle is having a hard time going into the new hub assembly. I checked for obstructions, and everything looks fine. I lined the teeth up and pushed as hard as I could, and it just didn't want to slide in. I even tried hammering. It doesn't want to go in! I thought maybe the axle's teeth could have been fucked up, but I was able to slide it in two other hubs I had laying around with NO problems.
Any suggestions on getting this axle in? I'm thinking if I pull the hub back off the car and work on getting the axle in it OFF the car, then bolting everything up. Any tips? FYI...the teeth look FINE.
-ryan
-ryan
Re: (HotRodDelSol)
The axle fits in OTHER hubs, so if anything the hub is damaged in one way or another. However...the hub looks fine to me...*shrug*
I need to spend more time on it.
-ryan
-ryan
Re: (Hatch4urSnatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch4urSnatch »</TD></TR><TR><TD CLASS="quote">try greasing up the splines of the axle. </TD></TR></TABLE>
That's what I was thinking of doing next.
-ryan
-ryan
Re: (B16Ej1)
Well I got the axle in the hub but due to the fact that I spent a few days beating on the end of it with a hammer to get it out of the OLD hub...it looks like I damaged some of the threads. Is it worth it to die the threads or should I just buy a new axle?
-ryan
-ryan
DelSol-B18
20
06-20-2012 01:30 PM
Coomer
07-06-2007 11:02 PM
