Axels...
Axels...
Im doin a second gen b16a swap in my civic CX i was wondering if im goin to have to change the hubs to fit the axels...And also im not sure so i thought i would ask. When you change axels does that take care of the CV joints...or is that a seperate thing. One last thing....can i use my harness for the b16 for the swap or am i goin to have to get a b16 harness. Cause i was told once that i can just use the CX harness...but im not really sure...if someone can help me out id really appreciate it. thanks fellas
Re: Axels... (screamincivik)
the axls will work in the hub as lond as they are the twin cam axels do not use your stock single cam one sit won't work you should ahve two axles ans a half shaft
oh and yes you can use the cx harness you just need to wire the knock sensor and vtec, and you need to relocate the o2 sensor it is pretty easy GOOD LUCK i had a b16a in my cx and i ran 14.4 on street tires
Eric724
04-12-2011 05:39 PM
Jdm John
09-07-2009 02:15 PM
