autozone advance auto b series d series radiators same
so i'm searching for a 2000 civic si radiator and it's the same part number as a 2000 civic dx..
im curious as to why this is because i know that the b series is different
Re: autozone advance auto b series d series radiators same
Many of your local parts stores will have the same part number for all civics from '92-00... which means that all will have the smaller inlet and outlets for the SOHC sized upper and lower radiator hoses. If you are lucky, there will be a pair of rubber inlet adapters... essentially a thin sleeve of radiator hose for each of the inlet and outlet tubes on the radiator. You would slip these over the necks first and then install your larger inner diameter "B" series radiator hoses. If the radiator doesn't come with them... don't buy it. I suggest you get a proper sized radiator and skip the local auto parts store stuff.
Not sure what prices you're looking at but personally I'd go for this:
GO-AUTOWORKS Civic/Integra Aluminum Radiators B16 B18 B20 Civic Integra CRX CRV
Go-Auto makes stout, great products. This would not only fit perfect and be an easy swap-in for you, not having to deal with adapters or any shoddy build quality or guess-work, but the full aluminum construction would definitely be a nice upgrade over OEM. Would look a lot better in the bay and perform better.
Just my .02
Just my .02
here is one I found listed for 95 del sol dohc, the difference is that the inlets are 1 1/4 for b series and 1 1/8 for d series I believe.
1995 HONDA CIVIC DEL SOL 1.6L L4 DOHC Radiator | RockAuto
More Information for OSC 1570
I have never used the above radiator but I believe it has the specs you are looking for, there used to be either a denso or koyo factory style that people were using with the 1.25 inlet outlets but I couldn't find it.
I got this one for my b16a in my 93 hatch and it had the larger inlets for the b series hoses
https://honda-tech.com/forums/perfor...deals-3174845/
Hence once again why I'd just recommend a cheap, inarguable upgrade with 0 guess work, but it's up to you obviously.
Ah, that's why I said citation needed. I thought even the B16 Civics still had single cores, never owned one of those from the factory though.
#1 Super Guy
You can get the Honda 99-00 Si one on Amazon for $225 shipped... 19010-P2T-A01 is dual core with larger hose headers.
Koyorad also makes a knockoff of the EG version for the Del Sol VTEC (B16) for about $100... Koyorad 19010 P30 G03
http://www.ebay.com/itm/NEW-Honda-Ci...3/151388894321
OP forget about the parts store junk get on rockauto.com and order one. I swear it will be 30 or 40 percent cheaper than a parts store
zerovandez
13
06-28-2007 08:36 PM
