auto trans slips to false neutral when warm--torque converter or sensor?
Old 02-28-2019, 01:46 PM
  #26
Default Re: auto trans slips to false neutral when warm--torque converter or sensor?
Your internal filter is stopping up for sure. You will need a new converter and transmission. When you turn the car off a lot of the stuff in your filter will drain out of your filter. When you crank it up it starts sucking it up until it completely stops up. Thatís why it runs fine until it gets hot.
The Torque converter lining sheds off and goes into the transmission and stops filter up.
WTRTransmission is offline
Old 03-01-2019, 10:43 PM
  #27
X2 on the clogged internal filter.
After an "unsuccessful" rebuild by a local Transmission guy on my wife's '93 Civic immediately failing within a few blocks of driving going into false neutrals,
the transmission guy said based on his 25 years experience the internal transmission filter was clogged.
Because the transmission had to get completely torn down again to replace the filter, I've recently replaced the original 25 y.o. radiator and added an external
inline filter in the radiator transmission cooler line (3/8 " Magnefine Brand) to help keep future crud from getting into the internal transmission filter.
Whether that will help or not - who knows... the filter company claims it will not restrict flow and will remove regular sediment and is also magnetic.
I think newer Hondas went to an external filter - so what the heck just another $25- and about a half-hours work.
Here are a few photos if your interested:
Magnefine Filter Installed on the Transmission Return Line From the radiator Cooling Tank
Inline Transmission Filter viewed from Above on the Return Line - Hose is Double-Clamped on the Return Line Pipe
4 Inches of Transmission Return Pipe Removed
Typical 92-95 Civic AT Trans Photo - Portion of Trans Return Line (in Red) Removed to Install Inline Filter
tj4fa is offline
Old 03-02-2019, 05:42 AM
  #28
I alway put a external filter on anything we install at our shop. Just for a added benefit.
Since Honda/Acura all have a internal filter.
Old 03-02-2019, 06:16 AM
  #29
tony_2018's Avatar
I put my filter before it hits the radiator or any external cooler to prevent the cooler from also getting clogged. Haven't had any issues.
tony_2018 is offline
Old 03-02-2019, 06:22 AM
  #30
We always bypass the radiator and run the external cooler on its own. It works great. And there is no contamination from the radiator or if it busted your transmission will still be fine.
Use a Hayden 1678 cooler 😄
Old 03-02-2019, 06:25 AM
  #31
I specialize in rebuilt Honda and Acura transmissions. I can wholesale you the transmission or we offer installation. We do over 2500 units a year and promise that our product and prices are the best in town. -Most jobs under $1500. -No hidden cost! -Free diagnostic! Call for a quote! 678-714-5571
judd_123
08-08-2011 05:38 AM
judd_123
Transmission & Drivetrain
08-06-2011 04:40 PM
jkwanus
01-29-2011 04:34 PM
alb_accord
04-06-2004 01:23 PM
crookedletterd
09-16-2001 07:14 PM
Quick Reply: auto trans slips to false neutral when warm--torque converter or sensor?
  • Ask a Question
Question Title:
Description:
