Auto to Manual Swap help
I have already searched but could not find the answer to my question. I picked up a set of mounts from someone that said they were for the swap. My question is: is there an easy way to tell if these are the correct mounts or not? I didn't want to find out after I pulled the motor and swapped transmissions. They are Innovative mounts if that makes a difference. Thanks for any help.
Re: Auto to Manual Swap help
take a look and compare them to the ones on now. and i did this swap a while ago and used my stock mounts. no problem 3 months later. just compare them.
ok thanks. they looked the same so I figured they were just stock replacements
OK, sorry to bump this thread but i'm having an issue and hoping to find a little help. I did the conversion and a mini me swap at the same time. everything works great except I no longer have a speedometer. I used the Y8 harness. My axle was shot so I used some newer ones my friend had( non-abs axles in my abs car). We replaced the VSS, replaced the cluster, still no speedo. Anyone have any ideas? thanks in advance.
