Auto-manual conv. question (axles?)
going to do this in the summer just getting everything ready. The axles? do i have to use ones from the tranny im putting in. It's going to be a y8 tranny on a y7 block. do i use the ones i already have or do i have to buy manual tranny axles? since im getting a y8 tranny on a y7 block do i use a dx manual ecu or a EX manual ecu.
Location: South Bay, Torrance/Carson, CA, United States
Re: Auto-manual conv. question (sleepyhamsterlx)
i was doing an auto to manual conversion on my d-series. and i found that the axles were exactly the same. so i think the might be the same on the auto and manual. this was on a 92-95 civic.
I've done an auto to manual conversion to a 1996-2000 Civic before. I believe the part numbers are the same for both the manual and automatic axles for the LX. It seems as though the EX has different part numbers for axles, but you should still be able to use your DX axles. As for the ecu, if you aren't swapping a head onto your Civic and just doing the transmission swap itself, a manual version of the ecu for your corresponding engine should suffice.
Re: Auto-manual conv. question (Blanka)
5 speed tranmission
clutch (pressure plate, disc)
shift linkage
manual ECU - more about this later
manual starter
flywheel
clutch master cylinder
slave cylinder
hydraulic lines
pedal assembly
tach - either a mounted one or a new cluster, helps with the downshifting
shifter
shift ****
shift boot
miscallaneous nuts and bolts!!
Front Mount Braket
u need the throw out bearing and what not
Thats all u really need, just make sure u get a manual ECU, or u will throw some codes
shift linkage
manual starter
flywheel
slave cylinder
hydraulic lines
pedal assembly
shifter
shift ****
shift boot
Front Mount Braket
Deuces_Wild
06-16-2006 10:47 AM
classciv
12-06-2005 11:50 AM
