B series head bolt size
Old 12-06-2015, 05:43 PM
White_EG1's Avatar
Default B series head bolt size
Okay what size is the stock B16 head bolts? Its weird, cause I tried a 12mm 3/8th which fit pretty good, but of course I cant loosen head bolts with a 3/8th, I tried a 1/2 12mm deep socket and it barely even fits in the hole, let alone grab onto the bolt.
So will a 1/2in 12mm non deep socket work?
Old 12-06-2015, 06:33 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: B series head bolt size
For stock head bolts, yes, you should be using a 6 point socket, non-deep well. Always use the right tool for the right job. You should be able to remove it just fine with a 3/8" ratchet. If you can't, just get a couple feet of lead pipe to slide over your ratchet. Boom, instant breaker bar.
Old 12-06-2015, 08:31 PM
JRCivic1's Avatar
Stock B16A head bolts are 14mm 6-point headed...
Last Friday morning, I removed a B16A2 head from the shortblock using a Craftsman 3/8" 14mm 6-point deep well socket with a 3/8 -> 1/2" adapter and a 1/2" breaker bar. Easy Peasy.
Old 12-07-2015, 07:45 AM
White_EG1's Avatar
Okay thanks guys, and I made a mistake, I was using 14mm the whole time. I don't have any lead pipe laying around, I do have a 1/2 breaker bar but not the socket to match it. So I'll just buy the non deep 14mm. The motor is sitting on this tall *** desk, taller than me, so I need all the leverage I can get.
blacc_ej1
06-01-2011 01:34 PM
oneprelude
03-20-2010 01:14 AM
kevodean
03-31-2009 01:24 PM
jyracer
01-13-2009 08:10 PM
1bar
05-23-2003 02:32 PM
Quick Reply: B series head bolt size
