auto to 5 speed problem
after finishing up at 2 in the morning, the car starts but wont move. I can shift it into first
and second gear without pressing the clutch and it doesnt stall or die. Shifting it into the
higher gears my rpms and speedometer jump up. STILL no wheel movement. YES axles
are in, i bled the clutch, and did everything i was suppose to. thanks - josh
Re: auto to 5 speed problem (EK tommy)
So what exactly is going on? Engine on you could go through gears without the clutch and the car isnt moving? Sounds like you have no clutch.
Sounds like your clutch/master cylinder are not working right if you can just shift with out a clutch, regardless of wheel movement or not. Sounds like your clutch is stuck in the disengauged position. Sounds like you get to take your tranny/clutch apart. hope you fix it. YOu sure that you bled the clutch right?
later
later
Re: auto to 5 speed problem (hall97civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hall97civic »</TD></TR><TR><TD CLASS="quote">Sounds like your clutch/master cylinder are not working right if you can just shift with out a clutch, regardless of wheel movement or not. Sounds like your clutch is stuck in the disengauged position. Sounds like you get to take your tranny/clutch apart. hope you fix it. YOu sure that you bled the clutch right?
later</TD></TR></TABLE>
lol, bled it too much, went through 3 bottles. i picked up another tranny hoping that that is the problem. i'll be switching it out in the morning i'll let you guys know how it went.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK tommy »</TD></TR><TR><TD CLASS="quote">BUMP, for a friend.</TD></TR></TABLE>
THANKS MAN, i'll swing by if i get it running
Re: (hall97civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hall97civic »</TD></TR><TR><TD CLASS="quote">what was the input shaft broke or something? Just curious what was wrong with the tranny?
thanks</TD></TR></TABLE>
not too sure, i didnt take it apart
zach1288
16
05-09-2007 05:57 AM
