ATTN: any other way to drain automatic fluid besides the drain plug
Old 01-24-2004, 06:54 PM
sleepyhamsterlx's Avatar
Default ATTN: any other way to drain automatic fluid besides the drain plug
ive tried to get the drain plug off all day. I even got this huge breaker bar(30 bucks and it still doesn't budge. I shake the whole engine/tranny when im putting all my force into it. Is there any other way to drain the automatic tranny i need to flush it out and put change the fluid. This is in a 98 lx sedan if that helps.
Old 01-24-2004, 06:57 PM
Dat Dere Cell Tech
daklown's Avatar
Default Re: ATTN: any other way to drain automatic fluid besides the drain plug (sleepyhamsterlx)
pull the axle out.
Old 01-24-2004, 07:24 PM
asmallsol's Avatar
put a small pipe over it. It shoudn't be that hard to get out. You are turning it the right way right? (counter clockwise = loosen y0!)
Old 01-24-2004, 07:30 PM
Default Re: (asmallsol)
yeah counterclockwise doesn't budge it, nothing is getting this thing loose i let the WD-40 soak forever and it still is giving me problems
Old 01-24-2004, 07:40 PM
asmallsol's Avatar
Default Re: (sleepyhamsterlx)
what the hell, your even in texas. I just did an auto to manual conversion plus swap on a 95 dx, here in the salt belt of michigan, with a small 2 foot pipe, it came right out and this thing you could tell that it had never been changed (gunk all over the drain plug)
Old 01-24-2004, 07:43 PM
[QUOTE=asmallsol]what the hellQUOTE]
? any suggestions
Old 01-24-2004, 07:49 PM
McFly's Avatar
You can try to tap on it a few times with a hammer, not too hard though. Then put the breaker bar back on and try it again. This can sometimes help get stuburn bolts out.
Old 01-24-2004, 08:14 PM
asmallsol's Avatar
suggestion? If you cant get it off, either pull the axle (pain) or get a very long straw and start sucking lol
x2gold's Avatar
Default Re: (McFly)
The best thing to do, I belive if it's the same as the EG's, and if you have air available is to take a 1/2" impact gun and place it in the hole for the drain plug. With a lot of air pressure, and minimal effort, the plug should break free.
Old 01-24-2004, 09:10 PM
Pooping on children
Discosteak's Avatar
Default Re: (x2gold)
i would use an impact gun but be careful you may end up snapping the bolt off inside the tranny
Old 01-25-2004, 05:19 AM
asmallsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x2gold &raquo;</TD></TR><TR><TD CLASS="quote">The best thing to do, I belive if it's the same as the EG's, and if you have air available is to take a 1/2" impact gun and place it in the hole for the drain plug. With a lot of air pressure, and minimal effort, the plug should break free. </TD></TR></TABLE>
the bolt is a 3/8's square that the drive justs snaps in there. If you go this route, you neet to buy a 1/2 to a 3/8 drive socket.
Old 01-25-2004, 06:45 AM
NonovUrbizniz's Avatar
it shouldn't be "shaking"...
Apply progessively harder pressure... If it's on a lift you would basically do a pull up on the breaker bar. If it's not try to get the bar poking out from under the front bumper... then balance ALL of your weight on the end of the breaker bar and hop a little... but there is a technique to breaking stuck bolts without breaking them. You want to apply force like you're DEFINATELY going to pass the point it's stuck on whether or not you will. It's kinda like punching through something instead of punching it...
Carefull though... snapping that bolt head off won't make this ordeal any easier.
Old 02-01-2004, 02:43 AM
GoFastOrGoShlow_HNDA4LIF's Avatar
Drill A Hole......
northkai3
26
09-29-2013 11:53 AM
Nooch
03-20-2011 06:37 AM
tchen415
07-15-2007 09:10 PM
dork
07-09-2004 02:01 PM
4doorLX
10-02-2002 10:55 AM
Quick Reply: ATTN: any other way to drain automatic fluid besides the drain plug
