attention: all eg6's with B18c1 swap........
i just took my cold air off for the winter here in T.O. and
put the GSR rubber intake arm and mounted it on my
OEM air box with a drop in K&N filter in it.....
my problem is that the rubber arm seems to be too long
for my box to stay bolted on the mountsof the chassis if you
know what i mean....if i bolt it int the hose starts to bend too much!
i just saw pics of houston hatchbacks set up and mine is exactly the
same only my box won't bolt in,.....its pushed up right against the headlight
and the hole in the body doesn't line up with the hole in the box......
do you have to cut the rubber down or what?????
please advis cuz i don't want to star moding the arm until
i know for sure...... thankx
Re: attention: all eg6's with B18c1 swap........ (SkyeC)
I have no idea what your problem is. Maybe your car is bent.
i do know my car has been in one
front end accident, i even had the
front end pulled, but i didn't think
it would throw this **** that off.....
Re: attention: all eg6's with B18c1 swap........ (J-SPEC-JEFF)
I have the same problem. Looks like "houston hatchback" used the civic intake box and the integra rubber arm/pipe.
The integra rubber arm/pipe's diameter is bigger than the civic intake box inlet. I think clamp would work.
I emailed "houston hatchback" about this already...awaiting for his response...
Re: attention: all eg6's with B18c1 swap........ (0gsR)
never mind i got it too fit and
and mine is the same set up as
the one above and houston hatchbacks,
.....GSR intake arm and stock civic air box.
justincredible1
05-31-2011 09:49 PM
JDMB16DA6
04-01-2003 05:07 PM
