ASAP need help with K24 swap in eg hatch.
I have never messed with this swap before and i need to know everything about the total swap. right now i have the engine and the car, but i need to know what i have to do exactly do get the car running ready to drive. Where can i get all the parts neeed for this swap. Need help cause i want to do this swap myself and i need all the info on this. Thanks ill update as the build goes on.
Re: ASAP need help with K24 swap in eg hatch. (egk24swap)
Re: ASAP need help with K24 swap in eg hatch. (teal_dx)
The following products are needed to complete a full K Series motor swap.
* K series motor/tranny/ECU
* K series engine harness
* K series charging harness
* B/D series coolant temp sensor and fan switch
* Universal Fuel Pressure regulator
* Custom Fit Fuel lines
* OEM RSX shifter Box or Modified Accord shifter box
* RSX Shifter Cables
* Shifter linkage Clips
* Aftermarket intake
* Aftermarket Header
* Custom Mid Pipe
* Throttle cable for your application
* EP3 pulley and belt (if retaining AC and OEM belt)
Are you running with Hybrid Racing Parts? Like Motor mounts, Conv Harness, Axles, Clutch Lines...
Let me know if you need help bro.
* Custom Mid Pipe
seanhatch95
Suspension & Brakes
04-07-2012 02:16 PM
seanhatch95
04-07-2012 06:27 AM
