Apexi WS vs. custom piping
I'm finally able to buy an exhaust, and i tried to search but couldnt find any direct comparisons. Basically, i just want to know which would make the most power of the two. The world sport would be 60mm(2.3in) piping right? And i'm assuming mandrel bent straight through design? Are there any fitment issues that anyone has had with it on there EX coupes? Thanks and sorry if this has been asked several times
I would go with the world sport if you are looking to get a good quality exhaust w/good fitment (this exhaust is NOT a high horse power exhaust!)
If you are looking for the most power you need to go with a straight through design such as an Apexi N1
as far as custom exhausts go -> I wouldnt expect any better gains and I hate the sound but if you think the sound of a weed eater is good be my guest
Re: (ITRacer121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRacer121 »</TD></TR><TR><TD CLASS="quote">I would go with the world sport if you are looking to get a good quality exhaust w/good fitment (this exhaust is NOT a high horse power exhaust!)
as far as custom exhausts go -> I wouldnt expect any better gains and I hate the sound but if you think the sound of a weed eater is good be my guest</TD></TR></TABLE>
Weed eater? That's what a resonator is for.
Re: Apexi WS vs. custom piping (DondaStyle)
The amt of power you will make depends mostly on ur current/future set up. A smaller diameter exhaust on a mild NA setup will make more useable hp then a bigger one.
If you are planning on staying under or around 200hp, IMO the WS would be ur best bet.
If you are planning on staying around 250hp, IMO 2.5in custom piping w/ a magnaflow muffler would be ur best bet.
Anymore then that and you want 3" piping.
You could find someone that would make you a straight through 2.25" piping with a WS muffler, thats probably the most ideal situation for a low out put situation.
If you get piping thats too big, you'll hurt mid range performance, it all depends on what u want.
