Apexi N1 pro dampers help!
* B A N N E D *
how do i tell wat model or i should sya year spec they are.. i havent installed em yet and i dont have the hex keys for the damping... so i could use to help amd pointers.. thanks
the number on them is 241-H008
they are hte Apexi n1 Pro Dampers
this is wat they look like except the rears have hte the forks for a 96-00
thats another thing i gotta 95 coupe imma try to fit these on any reccommendations?
your post was short but incredibly hard to understand....maybe its just me heh its 2 in the mornin and i been studyin for finals...anyways with a 95 coupe...if you want that specific set right there u use those jdm lca's u see at the top for the rears...if its the 96+ spec rear dampers ur gona use on ur car its a bit trickier....the lca of the EK is a bit fatter than the eg coupes so u wont be ablet to bolt it on without some play...only solution i can come up with is maybe some fat washers to place in the gap between the fork of the damper and the lca
* B A N N E D *
Re: (dc2vu)
na i kno abotu the rear lca. mines are for 96-00 and the 92-95 lca are fatter than 96and up so thats my one problem. i gotta like stretch open the rear forks
