Apexi N1
Apexi N1
i have a 98 civic hb with a b18c motor in it and i was woundering if i were to get get the apexi n1 would i have to modify it to make it fit or would it just bolt right up? I think it should but i just wanted to see if i was right from some of you guys that have that set up. thanks
Re: Apexi N1 (nasi)
I asked myslef and honda tech the same question. The think about getting an Exhaust that boldt up to an DC2 or EG chassis is the rear cross section. (under the car where you would bolt up a "lower tie brace", from right to left that is shorter on the EK's for some reason so it may cause some clearance problems. Yeah keep in mind your DX or CX most likely had that dumb *** pre-cat cat mounted in front of the engine instead of under and behind..... good luck let me know what you find.!
EK's are the ****
EK's are the ****
Re: Apexi N1 (chrisir19)
Get the exhaust ment for your car. The problem will be with the cat that you are running. You might need to lengthen or shorten that part. I would say get the N1 for your car then go to an exhaust shop and get a 2.5" test pipe made to connect the header and exhaust.
Re: Apexi N1 (King Tut33)
so you guys think that it will fit right up just fine. i don't want to hack any thing off and i realy don't want to run a test pipe . I an already getting a highflow cat from hybrid garage.
Location: around the corner to the left ... no, your other left
Re: Apexi N1 (976)
the n1 is dyno proven for power, but like home boy said, its loud. but you can get the full cat back exhaust specifically for your car. they make it for your car. dont get the universal one.
Re: Apexi N1 (ricancivicsi8)
i know its loud thats not an isue . i have a b18c in my hatch and was woundering if it would just bolt right up or would i have to get it cut to fit thats all.
Re: Apexi N1 (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">Don't do it, Apex N1 is way too loud bro!
The silncer doesn't even help much... </TD></TR></TABLE>
they are not too loud, i love them, and the silencer does work, had one on my prelude, only used it on long trips
Re: Apexi N1 (redintheface)
it should bolt right on, but if it doesnt u can always have an exhaust shop weld a tiny extension. and i have an N1 on my civic, it wasnt to loud, but now that i took out my cat, its loud as ****, if u dont like loud, make sure u keep ur cat.
