Anyone with this set up --- JDM 2nd gen B16 on a 5th gen civic
Hey guys, i just wanna see if some of you have this set up and can help me out as i do my B16 swap. currently i have a 95 dx that came with a 93 ex/si d16 when i bought the car. so i hope i dont run into any problems with the harness issue since its running with vtec. one of the many questions i have is about the mounts. would be able to use the stock mounts that are on my car? or do i need any other additional if not diff mounts from another car? please be a bit specific so i wont be a pest to some of u by re-posting. ill appreciate if i can email some of u with other questions that may arise. fyi, the b16 came with its hydro tranny, stock intake & exhaust manifolds, shift linkage, dist, starter, axles (one of which needs repair) and ecu. i would be dropping a stage 2 exedy clutch (yah i know its an exedy, but not bad if it was for free ) and skunk2 cam gears. maybe in a few months (for sure by summer hits around) i would have after market headers and a whole new exhaust including the cat. well thanx for reading and tia.
Re: Anyone with this set up --- JDM 2nd gen B16 on a 5th gen civic (sirminder)
ok for wiring, your gonna need to run a wire for the knock sensor (dont know the pinout off the top of my head, sorry)
mounts - transmission T bracket from a gsr or del sol vtec, and upper drivers side mount from the same (i think its those, dont remember. i used the mounts that came with my swap didnt reuse any stock ones) good luck with the swap, its not that difficult.
Re: Anyone with this set up --- JDM 2nd gen B16 on a 5th gen civic (KAMiN)
thanx for the reply kamin. anyone else know about the knock out sensor and how to do it? and is the T bracket mount u mentioned the same as the rear mount i often read about?
Use a P28 Hondata stage 2 to run the B16......you don't need to run the knock sensor wire then.
Might be easier.......
Steve
Steve
Re: Anyone with this set up --- JDM 2nd gen B16 on a 5th gen civic (stevecockrill)
yah that hondata stage 2 set up sounds good. but right now im a bit tight on money. dont even have the money for aftermarket headers yet. so i got to save up. but anyhow, keep them coming guys.
sirminder
05-07-2002 12:15 AM
