Anyone running Toda clutch / flywheel??
I'm planning on upgrading my clutch and flywheel soon. Is anyone running this setup. Or do you recommend a different clutch like exedy or ACT?? I am definitely getting the toda flywheel.
Re: Anyone running Toda clutch / flywheel?? (Tom)
im not...
You may be better off checking the Integra R board where they have more money than they know what to do with, I'm sure some of them have that stuff.
Re: Anyone running Toda clutch / flywheel?? (EbboyPSi)
I used to run a TODA flywheel (which is the same as Cusco) as well as Exedy 3-puck and HD pressure plate, at first it was rather tought to get used to but later you will appreciate the holding power, and how quickly it can rev and hold the power.
I defiantly recommend it
will do it again on the next swap, only thing I can add is that once you go past 12lbs and less as far as flywheel you can't really tell the difference (10-12lbs flywheel is a good compromise as far as B16A and torque loss)
Re: Anyone running Toda clutch / flywheel?? (Phantom)
im not...
Agreed.
Agreed.
BoostedGSRBubble
09-15-2002 09:50 AM
