Anyone with a OBD1 b18b in their EK?? Did my swap I am having problems getting it to start.........
I posted in the TECH forum but I am really desperate for help, just want someone to see it SOON..............thanks in advance. This is the thread: https://honda-tech.com/zerothread?id=420531
Re: Anyone with a OBD1 b18b in their EK?? Did my swap I am having problems getting it to start.....
Are you running any cels??? Is the VSS hooked up right??? Might be why your mph is jumpin around. Make sure the map and tps sensor are not switched as they are the same plugs.
Ya well i tried that switching plugs but still wont start. My main concern is gettin it started and i'll go from there. How funny 97hb I was just lookn for you but your IM is disabled. Hope you can help out.
Yeah, I dont have IM on this computer . Does the fuel pump prime when you turn the key??? If your not getting spark it could be something on the distuributor. You said it was running before so I assume that the ignitor is good. Did you have to rewire anything on the dist.???
Ya it was an OBD1 distributor so I soldered on an OBD2 plug, matched wire for wire. Same colors. And I don't hear the fuel pump prime. I figured it was something electrical or something cause car won't start even with my OBD2 CX ecu.
1 Post
dont know how much I can help, but I struggled for 7 months on an LSVTEC swap only to find out i was ONE tooth off in timing....check the timing again?
Mine jumped that tooth as well...
check fuses make sure you got the obd2 oil pump check timing just dont buy anything and dont replace anything so you can do process of elimitnation cuz you might be replacing things that doesnt need to be replace so non waste of money test everything first
Ya I am using an OBD1 ecu with a jumper harness I made cause the OBD1 LS block doesnt have the Crank sensor on the oil pump. So I have one extra plug for the crank sensor.
Could it be the distributor? Took off the distributor the cap looks fine but the rotor is stuck. If its the distributor could that explain my MPH jumping while cranking? And also could it explaining the clicking sound I hear coming from the ECU?
j4s0n1337
41
02-19-2011 07:50 PM
R883
10-07-2009 08:00 AM
civicrtype
02-26-2003 04:22 PM
