anyone know how to make....
anyone know how to make an OBDII engine run on just one O2 sensor properly? just trying to get my swap at least running kinda right. LMK if anyone knows how to make this work.
Re: anyone know how to make.... (SloazzEKhatch)
Why dont you just go to a muffler shop and have them weld up a bung for the secondary O2 sensor? Itll be hella cheap and it will make your car run like its supposed to. If not that you can buy a conversion harness and convert from obd2 to obd1.
Re: anyone know how to make.... (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">you can do an O2 simulator....
search for that</TD></TR></TABLE>
what exaclty is that?
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloazzEKhatch »</TD></TR><TR><TD CLASS="quote">
it involves resistors into ecu pinouts, etc.....you'll need to search or wait for someone else to answer, I can't tell you how
Re: anyone know how to make.... (aw1234dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aw1234dude »</TD></TR><TR><TD CLASS="quote">Why dont you just go to a muffler shop and have them weld up a bung for the secondary O2 sensor? Itll be hella cheap and it will make your car run like its supposed to. If not that you can buy a conversion harness and convert from obd2 to obd1.</TD></TR></TABLE>
where exactly would the other bung go on a GSR swap?
you'll need to search or wait for someone else to answer, I can't tell you how</TD></TR></TABLE>
haha ok
haha ok
You have to have them weld up the bung after the cat for the secondary O2 sensor. Thats where theyre always supposed to go.
and for the O2 sensor simulator.....
My friend soldered up a O2 sensor simulator "kit" he got off ebay on his impreza and it worked, kinda. Every now and then he throws a cel for malfunctuning O2 sensor. The "kit" isnt really a kit, its just like what Emerika said, a could resistors. You soldeder the resister inline between two of the wires on the o2 sensor. I think its kind of a shady way of doing this but i guess if it works its all good.
I say just spend a couple bucks and have a bung welded in and install a o2 sensor. Do it the right way the first time....
Guest
Posts: n/a
</TD></TR></TABLE> I love the "I can't tell you how." You make it sound like it's some top secret **** that once you tell him you'd have to kill him! Haha tell him then go get one of those things they had in Men in Black and erase his memory!
Re: anyone know how to make.... (egizzle6)
the secondary o2 is useless. it doesn't do anything. but it does have to be there. all you have to do is plug the secondary o2 into the harness and tie it to your front sway bar or something similer.
problem solved
problem solved
Re: anyone know how to make.... (scratchy)
well thanks to eveyone for the input. as for the performance of the motor; will it be affected at all by the missing o2 sensor?
i bought an 02 eliminator and it didn't work for ****.....i purchased it from casper electronics and i will be returning that product in the next two days......you get a winner or a dud......and i got screwed out of 100 dollars.....
swtch7
07-15-2005 03:19 PM
