Anyone know how to deploy an airbag?
Got one laying around the shop. Trying to have some fun. Didnt work with straight 12v. Does anyone know the trick to it?
It's from a Civic
It's from a Civic
Re: Anyone know how to deploy an airbag? (94si94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx »</TD></TR><TR><TD CLASS="quote">Got one laying around the shop. Trying to have some fun. Didnt work with straight 12v. Does anyone know the trick to it?
It's from a Civic </TD></TR></TABLE>
that sounds like a really bad idea. Do you have some want for a chemical burn?
Re: Anyone know how to deploy an airbag? (dpw41285)
Sounds like a bad idea? We are about 100ft away with LONG wires. I just need to know HOW to blow it up, not whether I should or not.
we used to do that at the dealership for recalls all the time. there is usually a device that does it but you should be able to do it with just a battery. hint: turn it upside down and watch it shoot 25 feet in the air! it's loud as **** too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx »</TD></TR><TR><TD CLASS="quote">Sounds like a bad idea? We are about 100ft away with LONG wires. I just need to know HOW to blow it up, not whether I should or not.</TD></TR></TABLE>
granted that you are very far away... it might be safe.. if you find out how to do it.. you have to record and post it.
Re: Anyone know how to deploy an airbag? (SpoolinEH2)
have you tried connecting it to the 12v battery then touching the + and - together? that might do it ..ive never done this before but i also have one that id like to do someday..i think the idea of turning it upside down and launching it into the air is great
Re: Anyone know how to deploy an airbag? (Grip)
Ok, we did figure it out. Didn't have anything to record it with though.
You ground the body of the airbag. There are 2 pink wires. Ground one of them also, and then connect the body/pink wire to the (-) and the other pink to (+). Pretty impressive.
Also note, we had it BOLTED to a big industrial dumpster, and it moved the dumpster and broke the bolts off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94si94cx »</TD></TR><TR><TD CLASS="quote">Ok, we did figure it out. Didn't have anything to record it with though.
Also note, we had it BOLTED to a big industrial dumpster, and it moved the dumpster and broke the bolts off. </TD></TR></TABLE>
that's the type of force I look forward to when I get into an accident.
be professional
Re: Anyone know how to deploy an airbag? (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">
that's the type of force I look forward to when I get into an accident. </TD></TR></TABLE>
Feels better than smashing in your face on the vinyl-wrapped metal rim of the steering wheel . . .
Besides, if you're wearing your seat belt like you should, it will hold you back from the full force of the airbag.
Re: Anyone know how to deploy an airbag? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Besides, if you're wearing your seat belt like you should, it will hold you back from the full force of the airbag.</TD></TR></TABLE>
true.. but it sounds menacing.... I guess when observed in that way I would opt for the chemical burns and a rip stop nylon bag in the face.
1 Post
true.. but it sounds menacing.... I guess when observed in that way I would opt for the chemical burns and a rip stop nylon bag in the face.</TD></TR></TABLE>
Coming from first hand experience a few times, you do not get chimical burns. The only burn you get is compareable to rug burn from you face dragging across the air bag.
1 Post
Re: Anyone know how to deploy an airbag? (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">
Coming from first hand experience a few times, you do not get chimical burns. The only burn you get is compareable to rug burn from you face dragging across the air bag.</TD></TR></TABLE>
yeah, those airbags are very hot when they deploy, also
1 Post
Re: Anyone know how to deploy an airbag? (blackhatchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy »</TD></TR><TR><TD CLASS="quote">
yeah, those airbags are very hot when they deploy, also </TD></TR></TABLE>
Yea they are...but thank God that the material they are made out of does not hold heat well. From my experience the bag itself cools off in a matter of seconds. The steering wheel on the other hand stays hot for quite some time.
Risky Business
Anyone know how to deploy an airbag? </TD></TR></TABLE>
Plug it into your steering wheel and drive as fast as you can into a tree.
Re: Anyone know how to deploy an airbag? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Plug it into your steering wheel and drive as fast as you can into a tree.</TD></TR></TABLE>
Why is it the guys with the most posts always have the most clever responses, but the Trial Users never have anything good to say?
Right when I saw the thread title I knew I was gonna say that, but then judging by the number of posts I also assumed it would have already been said so I read through. I'm amazed it took so long...
Re: Anyone know how to deploy an airbag? (MichaelJComputer)
Strap a couple m90s to it and blow it up. if this does not work take it and put it against a tree grab a shotgun or a glock and then start blasting the the hell out of it.
buddy of mine did this a few months ago, wasnt paying too much attention, so all i know is that he just wired it right up to a car bat. it was turned upside down so it shot in the air about 20 ft. have fun
nasaproracer
25
03-22-2004 04:34 PM
jdmspoonitr
11-21-2003 07:41 AM
