Anyone Here Drilled a Hole in an EK For CAI?
just wondering what tools/method you guys used to do this. i want to do this but don't want it to look ghetto. Can a shop do this and come out clean looking?
jus f0 dekarayshunZ
Re: Anyone Here Drilled a Hole in an EK For CAI? (BI8B)
i did it on my friends...it came out nice it was a nice round circle...i used a dremel and it worked nicely....theres an outline of where the hole should go
I did it, but I honestly regret it. I used a knife. It turned out nice, but I just don't like seeing that hole there all the time. Plus, your filter gets dirty alot faster.
Re: Anyone Here Drilled a Hole in an EK For CAI? (slvrcivic97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcivic97 »</TD></TR><TR><TD CLASS="quote">I did it, but I honestly regret it. I used a knife. It turned out nice, but I just don't like seeing that hole there all the time. Plus, your filter gets dirty alot faster. </TD></TR></TABLE>
that doesn't make any sense. the ITR and Si CAIs both put the filters in the same spot... they just rout the piping different ways.
New User
Re: Anyone Here Drilled a Hole in an EK For CAI? (ciRcuitSi)
you must be very stong to cut that metal piece out with a knife. circuit, you have pics of the hole you cut?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuitSi »</TD></TR><TR><TD CLASS="quote">hmmm im confused silver?? you need to make a hole for a cai on a hb</TD></TR></TABLE>
only if you use the intake from a 99-00 Si. ITR and GSR intakes go under the frame. you don't need to cut or anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BI8B »</TD></TR><TR><TD CLASS="quote">what did you use to cut out the hole?</TD></TR></TABLE>
Did you not read what Circuit said.
Re: Anyone Here Drilled a Hole in an EK For CAI? (Chris y0!)
i have a sold air for my Ek and you don't cut a hole, the piping runs right of where the normal hole is for a intake and then goes down behind the bumper and goes to the left in to the fender, stick your hand down there feel around, i do believe it is the same on g3 tegs
jus f0 dekarayshunZ
Re: Anyone Here Drilled a Hole in an EK For CAI? (hondaciv3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaciv3 »</TD></TR><TR><TD CLASS="quote">i have a sold air for my Ek and you don't cut a hole, the piping runs right of where the normal hole is for a intake and then goes down behind the bumper and goes to the left in to the fender, stick your hand down there feel around, i do believe it is the same on g3 tegs</TD></TR></TABLE>hi lets give people wrong advice...thanks jeeves i think we got it handled...i used a dremel and the cold air does in fact go through the place where you cut a hole
jus f0 dekarayshunZ
Re: Anyone Here Drilled a Hole in an EK For CAI? (Unjockable)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unjockable »</TD></TR><TR><TD CLASS="quote">you must be very stong to cut that metal piece out with a knife. circuit, you have pics of the hole you cut?</TD></TR></TABLE>sorry no pics...ill see if i can get some...actually it depends on the intake you have...my friend has the si cai so if thats the one you haev the you need a hole...if you have a gsr motor and the gsr intake then you dont need to cut a hole
yeah you definitely have to cut a hole for CAI on ek's. I used a drill to start the hole and then airplane snips to cut it, then dremeled it smooth, looks stock. Yeah there is an outline so its pretty easy.
jus f0 dekarayshunZ
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">yeah you definitely have to cut a hole for CAI on ek's. I used a drill to start the hole and then airplane snips to cut it, then dremeled it smooth, looks stock. Yeah there is an outline so its pretty easy. </TD></TR></TABLE>it depends on the intake...si intakes go through the hole...integra intakes dont because the abs is over on that side so it goes around that metal piece thanks chris for assisting
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">yeah you definitely have to cut a hole for CAI on ek's. </TD></TR></TABLE>
i give up forget it
i give up forget it
Re: (Chris y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">
i give up forget it</TD></TR></TABLE>
this is a prime example of why VAGUE questions shouldn't be made. people are answering this guys' questions in two totally different ways.
edit......we can't assume which intake this guy wants to run....integra or civic....
jus f0 dekarayshunZ
Re: (B16b2b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b2b »</TD></TR><TR><TD CLASS="quote">
edit......we can't assume which intake this guy wants to run....integra or civic....</TD></TR></TABLE> i answered the question for both intakes so did chris
Modified by ciRcuitSi at 6:58 PM 7/20/2003
Re: (ciRcuitSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuitSi »</TD></TR><TR><TD CLASS="quote"> i answered the question for both intakes so did chris</TD></TR></TABLE>
i appreciate that, but the dumbass hasn't even posted again...it's just ignorant, that's all.
Re: (B16b2b)
i appreciate that, but the dumbass hasn't even posted again...it's just ignorant, that's all.</TD></TR></TABLE>
sorry this dumbass couldn't post because of being a newbie. 5 post in 24 hours. i wish i can post anytime just like you, master poster.
Re: (BI8B)
master poster. </TD></TR></TABLE>
don't forget it, newbie .......
Re: (B16b2b)
don't forget it, newbie ....... </TD></TR></TABLE>
never did. that's why i stated myself as a newbie.
blackstar
01-30-2005 10:12 PM
