anyone else have problems w/ their projector lamps?
i have the denji projector lamps and for some strange reason the right side low beam is too loose, the bulb doesnt seem to make solid contact w/ the ground and thus flickers on and off sometimes.
i dont know what to do to remedy this, just wondering if anyone else has had the same problem?
Re: anyone else have problems w/ their projector lamps? (lucas569)
i had that problem also with my old 94 civic, hit a bump and it would go on then off etc...
Re: anyone else have problems w/ their projector lamps? (jeddy0120)
did you end up fixing it? if so how?
i used to have the same problem,try to adjust the headlight so the clip that holds the bulb in place isn't touching the plastic coer i did this and i never had a problem after,i used to hate it because 99% of time i would turn my headlights on that side wouldn't turn on hope this helps
Re: anyone else have problems w/ their projector lamps? (singlecam screamer)
I have them and they work fine. kinda
The driving beams are actually worse than my stock setup.
What i did was aim the high beam down and now i use that as my driving beam, I don't even use the originally intended driving beams.
Re: anyone else have problems w/ their projector lamps? (2CAMSAAM)
projector headlights that use H3 bulbs royally suck... believe me, my friends and I all know first hand.
Re: anyone else have problems w/ their projector lamps? (PatrickGSR94)
are there other projector lamps for 92-95 civics that dont use the H3?
is there a way to fit a diffirent bulb?
[Modified by lucas569, 3:29 AM 10/5/2002]
try scratching off all the paint befroe you ground it, then reground. make sure youre hitting bare metal
Re: anyone else have problems w/ their projector lamps? (Searching...)
for best results read my post above.
I CAN CEE!!!
the highbeams that i use as driving beams use an H1. You cant 30 times better.
The H3 lense is pretty shitty. Sometimes its like its not even on when using the H3, specially in the rain.
I also tried the 9006 (rewired to accept the 9006) in my H3 housing that was originally designed for the driving beam and it was still shitty. Starting to think that the "projector lense" was making the light projected worse.
I CAN CEE!!!
Don'tKnoKnuthin
09-13-2013 08:35 AM
