Anyone with a 99-00 EX or SI please help with wire color code
I bought a 99EX shell to replace my wrecked 96EX civic but one of the conecotrs is missing from the main harness conector C446. It is the Green connector that is right in front of the ECU. I need the wire color and pin numbers for the male side of the conector. I got a pin out diagram already but it just tells you the color like green but it doesnt mention the grey stripes because i got 2 green and blk wires but one had one grey strip and the other had 2 grey stripes. I would really apreciate if anyone with a 99-00 EX or Si can just take a look and the conector and tell me the exact wire colors and pin numbers on the male side.
Re: Anyone with a 99-00 EX or SI please help with wire color code (cruzan007)
Id like to help you on it, but I dont see a C446 connector in the Civic ETM book. Are you sure it is C446? The only connectors I see close to the ecu that I believe you are talking about are C131 (connects to engine wire harness) and C452 (connects to ECM/PCM connector A) both from the main wire harness. If you could check the number of the connector again, and find out, I will take a look at my car and tell you.
Re: Anyone with a 99-00 EX or SI please help with wire color code (vtecpower1062)
Thats the conector I am talking about i think C446 is the male side that connects to C131. Thanks in advance.
94eg5squadMD
02-02-2015 10:15 PM
