anybody have vacuum diagram for clutch.. i need help..
i have a 94 cx hatch. i know the clutch master cylinder is bad... clutch stays on the floor sometimes. especially after a hard left.... but once the car warms up if you push the clutch in the idle drops and sometimes so much that it just stalls out.
could this be an added symptom of the bad MS, or is there also a vacuum problem? all my lines dealing with the clutch seem fine. but it is getting a little hard to drive when you cant push the clutch in at idle..... PLEASE HELP ME!!!!!! |
Re: anybody have vacuum diagram for clutch.. i need help.. (SOHC Beast)
anybody. i have looked and i dont see any vacuum lines... but everybody says it is run from a vacuum sorce....help...
Re: anybody have vacuum diagram for clutch.. i need help.. (.:s h a w n D:.)
As far as I know the clutch doesn't have anything to do with vacuum. it's simply a pedal, MC and slave cylinder with some lines.
The brake system has the Vacuum booster but not the clutch. |
one more thing.. any reason why the idle would drop(almost stall) when the cars warmed up and you push the clutch in??
Re: (.:s h a w n D:.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:s h a w n D:. »</TD></TR><TR><TD CLASS="quote">one more thing.. any reason why the idle would drop(almost stall) when the cars warmed up and you push the clutch in?? </TD></TR></TABLE>
_________________ |
ya mean when sitting there for a long time and then pushing in the clutch? or pulling up to a stop light?
Re: (Relic1)
once i have been driving the car a lot... after it has fully warmed up. anytime you push the clutch in when the car i at idle it will drop real low and most of the time stall. weather i stop at a red light and hold the clutch in, or just sitting in a drive through... whatever.... i know the clutch master cylinder is bad... just dont know if it could be something caused because the MS is bad?
do you have any ideas why it is messing up? TIA |
Re: (SOHC Beast)
still need some ideas....i cant be the only freak to have had a problem like this?
