Anybody 92-95 civic hatch seals leaking water inside???
Old 10-23-2002, 06:30 PM
Houston Hatchback's Avatar
Default Anybody 92-95 civic hatch seals leaking water inside???
ya i dont know where the water coming from but i even tighten my hatch latch and still water is still coming in.. im getting tire of wiping it out every time it rain and just wanna fix it now.so anybody having the same problem as me or what.and if i do need to fix it do i need to get new hatch seals and from where. i dont wanna go to honda cause they charge a grip and i dont wanna leave it cause of water. is there some kinda after market seals i can buy thanks ....
Old 10-23-2002, 06:31 PM
ahcjar103's Avatar
Default Re: Anybody 92-95 civic hatch seals leaking water inside??? (Houston Hatchback)
it happens. fairly common occurence. it's an old car.
Old 10-23-2002, 06:38 PM
i know that but i wanna fix it
Old 10-23-2002, 06:45 PM
schtozo's Avatar
i had the same problem but fixed like 8 months ago and
it was leaking like as hell from the hole where the top of the hatch strut fit on the frame of car. was the left side... it had a small hole between the hatch rubber and the metal of car.. put some bondo and fixed... you can put cilicone too if you have same problem...
hope that helps...
Old 10-23-2002, 07:15 PM
AThiker's Avatar
I had a del sol for a while and had the same problem with the roof, and I used a 100% silicone lubricant which solved the problem completly. As long as you put some of that stuff on a couple times a year it should help. I used the spray at first which didn't work that well, I would recommend the stuff in the tube, you can work it into the rubber better.
Old 10-23-2002, 07:18 PM
New User
S&P500ITR's Avatar
LOL...Mine had the same problem. Mine was actually leaking from the plastic rear window shock mounts. I replaced them and the problem was taken care of.
Old 10-23-2002, 08:17 PM
White S2k's Avatar
mine leaks pretty bad
it leaks so bad that when it rains the water goes into my brake lights and blows out the bulb sometimes
EntuneCrx
03-01-2005 08:18 AM
tommyboy
09-19-2004 11:45 AM
crx_88_si
10
02-23-2004 04:27 AM
integra97R
10-03-2003 09:13 AM
Quick Reply: Anybody 92-95 civic hatch seals leaking water inside???
