Any1 install HIDs on their ek?
I got a 99 Civic and after putting the bulb in, but there is a pin that im havin trouble getting the pin 2 align back in so i can screw it in. So if any1 has done this before, tell me what u did.
Thanx
Thanx
Re: Any1 install HIDs on their ek? (JaeEK)
What pin? Don't put hid's in a ek it looks like crap at night and other drivers will hate you. The ek housings are not made for hid lighting and they have large amounts of glare and a lot of hot spots. Btw Hid's are plug and play I don't see why you had to remove a screw?
what are u saying?
i put HIDs in my Ej8 and i do believe that the bulbs just line up they are shaped to fit....if urs dont fit try swapping the bulb to the other side that might b it but I exactly sure what u mean just throwning out ideas are they the right size bulbs??
Re: Any1 install HIDs on their ek? (ejoner)
yea i know there plug play but theres a pin thats screwed in that holds in the bulb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeEK »</TD></TR><TR><TD CLASS="quote">I got a 99 Civic and after putting the bulb in, but there is a pin that im havin trouble getting the pin 2 align back in so i can screw it in. So if any1 has done this before, tell me what u did.
Thanx </TD></TR></TABLE>
which type of bulb are you using
H4(9003)
H4(9003)
well i havent checked what type of bulb, i asked for a 99 civic bulb and thats what he gave me. it fits in fine w/o taking out the headlight, its just getting the pin 2 stay so i can screw it in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner »</TD></TR><TR><TD CLASS="quote">Don't put hid's in a ek it looks like crap at night and other drivers will hate you. </TD></TR></TABLE>
Personal opinion?
Personal opinion?
Ek Forever y0!
Re: (JaeEK)
plug and plays looked and performed terribly on the two sets I had.
Phillips X-treme bulbs are the best bulb you can buy and outperform either of the HID pnp kits I had.
You have a halogen housing, stick with a halogen bulb.
My pnp kit Doesn't glair at all...and I have Stock housing....they shine bright but dont blind you have never had anyone flash me coming towards me and I have let someone drive my car towards me and I was in aother car and they where good....they only problem I have seen wit HID kits is wit aftermarket house and the aiming of them!!
Re: (BlkCivicFromTeamMNR.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkCivicFromTeamMNR.com »</TD></TR><TR><TD CLASS="quote">My pnp kit Doesn't glair at all...and I have Stock housing....they shine bright but dont blind you have never had anyone flash me coming towards me and I have let someone drive my car towards me and I was in aother car and they where good....they only problem I have seen wit HID kits is wit aftermarket house and the aiming of them!!</TD></TR></TABLE>
There is no Cut off in a PnP which is the problem...
there is no replacement for a retro fitted HID the out put is 3-5 times brighter...
dont believ me? there is actually two threads in appearance you can search for a PnP HID thread and a Retrofit thread go there and look at the outputs and cut offs.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner »</TD></TR><TR><TD CLASS="quote">Don't put hid's in a ek it looks like crap at night and other drivers will hate you.</TD></TR></TABLE> Who cares what other people think . And they dont look like crap if you aim them right.
my s2000 headlight is a lot nicer than the ek but the plug n play kit versus halogen is a big upgrade itself. I've had 4 plug n play kits and been happy with all of them. Get a quality pnp kit with a caster shield, it helps a lot with glare.
dude i took that pin off. i put it in using those rubber grommets from the factory lights. before then i cut off the metal piece that goes over the bulb while its in the housing. so all u see is purple everywhere. i dont care bout no other driver..f*k it
Re: Any1 install HIDs on their ek? (Spoonsinglecam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoonsinglecam »</TD></TR><TR><TD CLASS="quote">dude i took that pin off. i put it in using those rubber grommets from the factory lights. before then i cut off the metal piece that goes over the bulb while its in the housing. so all u see is purple everywhere. i dont care bout no other driver..f*k it</TD></TR></TABLE>
People like you shouldn't have licenses.
