any way to test to to see if a headgasket is blown?
Old 09-28-2004, 07:47 AM
mykeshonda's Avatar
Default any way to test to to see if a headgasket is blown?
any help or way to test a headgasket?
mykeshonda is offline
Old 09-28-2004, 07:48 AM
TSPeed Factory
AzntaggeR's Avatar
Default Re: any way to test to to see if a headgasket is blown? (mykeshonda)
compression and leak down test.
if your headgasket is blown you will notice symptons such as oil mixing in the with coolant and such.
AzntaggeR is offline
Old 09-28-2004, 08:59 AM
Default Re: any way to test to to see if a headgasket is blown? (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">compression and leak down test.
if your headgasket is blown you will notice symptons such as oil mixing in the with coolant and such.</TD></TR></TABLE>Correct.
Revolver is offline
Old 09-28-2004, 09:01 AM
Electrician
Deemeetree's Avatar
I concur.
Deemeetree is offline
Old 09-28-2004, 09:08 AM
Phatch99's Avatar
Default Re: (Dimi)
I believe you'll see what smoke too coming out of your exhaust.
Phatch99 is offline
Old 09-28-2004, 09:19 AM
spyderracing's Avatar
Default Re: (Phatch99)
You may also notice a phat oily coolanty mess in your engine bay....
spyderracing is offline
jackfast
03-25-2009 07:05 AM
cetcivic
01-21-2008 05:40 PM
Typeron
01-05-2006 07:37 PM
dutchman5
08-05-2004 02:58 PM
Racerage1
10-17-2003 04:15 AM
Quick Reply: any way to test to to see if a headgasket is blown?
  • Ask a Question
Question Title:
Description:
