Any way to check cel's without a gauge cluster?
I just finished a obd2 jdm gsr swap in a 98 hatch. I would like to check to see if it has cel's and which ones but I dont have a gauge cluster yet. Is there any way to check it w/ out the cluster?
Re: Any way to check cel's without a gauge cluster? (trecool44)
if yours is OBD2, i believe you wont be able to use the service pin connector's like those found in 1992-1995 civic's
you might have to go to your local autozone or something, and rent a OBD2 scanner/code reader |
You need a odb II scan tool
