Any Real Gain to Removing A/C System?
Re: Any Real Gain to Removing A/C System?
other then weight, no.
i don't know how people see through there windshield on a rainy night...i use my defrost alot
Well if ur like me and dont have one in the car then I hires you can rock a bigger radiator and fit some more stuff in that area but if not then there's no real advantage.... And if ur in a hot state then its probably a bad deal to start off with since imo in good ol tx and it gets well over 100
I`m in Jersey, so the summer`s can be hot. Only reason for this thread is because the system doesn`s hold a charge, and I really dont wanna spend the money to have it fixed..
You really will not notice any gains. You gain a couple HP simply because the engine doesn't have to turn that extra belt.
If you run it, there is a difference...maybe 3-4 whp. But if you turn it off at the track, you'll only lose about 1 whp since there's no tension on the AC clutch. I did before and after dynos with the belt on and off and confirmed the 1whp difference. On a daily driver in sweltering NJ summers, it's definitely not worth removing. Get it fixed...it could be a bad relay, not the AC charge...I found that out the hard way. The relay is probably 20 years old and the solder joints crack causing sporadic operation, particularly when it's hot.
As another poster said, it's nearly impossible to see in rain or high humidity without the AC. I kept mine when it was a daily driver. Now that it's going to be primarily a track car, I pulled it out. Not so much for the power diff, but for the weight (about 40lbs). That weight does add up when trying to trim it down for the track. Also, the extra room allows for more flexibility with headers, turbos and such if you're so inclined.
fm
fm
Yea, I kinda figured that would be the consensus. I was just getting an idea on what the big deal was people pulling the AC on a dd.
fm
fm
ive also been told that on an all motor K atleast that the difference between a motor that has AC and PS still attached and one with a k tuned pulley kit or something similar is like 8-10whp..
If you look around theres a dyno that shows 2whp gain, not worth it IHMO. Whats 2 horsepower if you get out of your car soaking wet and smelling like ****. If you don't want to fix it leave it be, but really its probably just a worn hose or something.
The AC belt is like a 20 inch and the AC pulley weighs maybe a pound. You'd make a bigger different changing your spark plugs every 3k miles.
Still, unless it's a track use car, or you live in a milder climate, I'd keep the A/C.
fm
Originally Posted by Translation
You lose what? There's less parasitic loss, more room in the engine bay, and less heat
If you're from SoCal, where there's really only super winter or super summer, you kind of need a/c.. Or at least that's how it is in my part of LA
