any one konw? knock sensor on a 99 DX hatch?
i wanted to know i just did a mini me swap and im not sure where the knock sensor is also do i need if for vtec to pop?
Re: any one konw? knock sensor on a 99 DX hatch?
more info? im assuming its swapped, since dx models never came with the vtak sauce. either way, yes, you need a knock sensor if youre staying obd1 in order for vtec to work. it should be located right above your oil filter.
Technical Hero
bseries but its the same relative location for d series
the y7 doesn't have one from the factory, you'll have to get one from a b series vtec or D16Y8
VTEC will still work without it
so will i have to tap into the block or somthing or is there a sensor there already
basically i have a 99 civic dx non vtec and i didi a mini me and i heard that i need a knock sensor ?
can i do without one?
where is it on the y7 block because i cant find it?
