Any more ways to get more MPG out of my 98 Civic HX?
Old 04-04-2007, 04:30 AM
rhgindc's Avatar
Default Any more ways to get more MPG out of my 98 Civic HX?
I just purchased a 98 Civic HX in very clean condition. It is completely stock. I'm wanting to know what basic modifications I can do to increase the fuel economy even more. I'm not really interested in getting more performance (if I can and get better mileage I'm okay with that, for sure) but really interested in getting the maximum gas mileage that I can!
Thanks
Old 04-04-2007, 05:11 AM
Darth ModerVader
Padawan's Avatar
Default Re: Any more ways to get more MPG out of my 98 Civic HX? (rhgindc)
Install a freer-flowing air filter, make sure your tires are properly inflated, bring all the maintenance up to date, remove power steering (if the DX has P/S - I'm not certain), have your fuel injectors cleaned and reconditioned, double-check spark plug gap, et cetera.
Old 04-04-2007, 05:12 AM
95ProjectEJ1's Avatar
Drop a K&N air filter into the box? Stay out of high rpms even if it means a "not so fast" take off.
Old 04-04-2007, 05:16 AM
hatchness135's Avatar
Default Re: Any more ways to get more MPG out of my 98 Civic HX? (95ProjectEJ1)
give it a proper tune
Old 04-04-2007, 05:26 AM
JDMFantasy2k's Avatar
Default Re: Any more ways to get more MPG out of my 98 Civic HX? (hatchness135)
try shaving some weight. get some ultra light weight wheels. Losing unsprung weight should make a difference. Maybe you could create a warm air intake like those crazy insight owners make.
Old 04-04-2007, 07:15 AM
pdiggitydogg's Avatar
Put on thinner tires and add a well designed front lower lip.
Consider a moderate set of lowering springs to lower the amount of air that travels under the car as well
You could go as far as adding an AFC to lean out the fuel map a bit, sealing the hood spaces with silicone and blocking off the upper grill w/ a sheet of abs plastic from behind (but thats a little extreme)
Old 04-04-2007, 07:24 AM
kaiba's Avatar
Are you getting OEM spec MPG.
jimt84
05-30-2015 05:38 AM
NeMiZiS
28
07-31-2014 12:29 PM
zenon8890
20
01-04-2009 11:40 AM
SRd240sx
18
11-01-2005 06:29 PM
xXcivicsedanxX
08-07-2001 01:45 PM
Quick Reply: Any more ways to get more MPG out of my 98 Civic HX?
