Antenna to back center conversion
yes it can. you need one of those short rubber antenna's and you need to put a hole in the rear center of your roof then you need to run the wire through your head liner, through your a-pillar, to behind your dash, into your radio, then you need to patch that hole from your original antenna
Re: (frosteg6)
IMO stock looks so much better why go through all of that treble if you don't like it there shave it pay the money for XM or Sirrus and get the high power antenna and put it on the rear shelf just my .02
Re: Antenna to back center conversion (m0dr0cker)
fyi its called a FUBA antenna... http://www.parts4vws.com
Re: Antenna to back center conversion (ScrapinSi)
that is the Antenna used with sirrius or XM? that sony makes they say it has a higher power rating so you can use it inside the car.
kaotikvizion
15
11-05-2013 07:44 PM
specoperformance
09-16-2008 01:28 PM
mrtoastyjr
11
10-30-2005 06:45 PM
done
08-04-2002 11:12 PM
