Another Trans Whine Question, but different....
A friend in my hometown just recently bought a 95 hatch with a b16 and ys1 tranny with factory LSD....Here's the problem: (the lower the speed the more noticable it is)..when cruising with foot on the gas the car makes a whinning sound that gets more high pitched as speed increases. When his foot is off the gas, or the clutch pedal is pushed in, the whinning stops completely (decel and idle there is no noise at all)...the car drives perfectly, and the trans oil was just recently replaced when he got the car. Almost sounds supercharged (its not obviosly). It's not particularly loud, and on the highway (60mph+) you cant hear it at all.
My master tech friend thought it could be the angle of the axles in the tranny because the car is lowered, and its not the original motor (hence geometry differences)..(he's old school and I explained I've had a few hatches in the past with a b-series and never had this whinning noise) Or he said it could possibly be the input shaft in the trans has a worn bearing.
Anyone else have this problem? what did they do about it? and is it particularly dangerous? car drives fine, I told him to rock it until something breaks. Could it be the LSD?
did you use synthetic fluid? and the best way to determine the problem is try to get the car on a dyno and just drive it normal and use a stehascope to hear if the whine is in the housing or the case.
yeah i was about to say throw out bearing is more than likely causing it. mine is bad right now and that is how it sounds. its just annoying after a while it will need replacing. first gear you hear it the most and after that it is no big deal.
He used oem Honda synth with friction mods...it was making the same sound before the fluid change also. What's the difference between the trans housing and case?
Throwout bearing...really??? I didn't think that could cause that....I've heard bad throwouts making a whirrly chunky type noise, but not a whine...If it was a throwout bearing wouldn't I hear something when at idle with the clutch pedal out and car in neutral?
a throwout bearing isnt too expensive. minus the labor, it wont be too big of a deal if you replaced it and the problem was still there.
yes, in my case, i heard the noise after a few miles and the car was warmed up. the whining noise would be there always after that, even at idle, driving, etc.
the housing is where the clutch and flywheel sit ( a sound from here would indicate a throwout bearing or maybe input shaft bearing) the case is where all the gears are and if the noise comes from there it really could be alot of things. main shaft bearing, countershaft bearing, differential bearings, worn gears. thats pretty much it but if that was it then the tranny would need to be torn down and inspected for those things.
My bet is the isb with the way the noise is. If it was a throwout bearing you should only hear it when you push the clutch in other wise the throwout bearing isn't really doing anything
nope you got it back asswards. you will hear the the throw out bearing when the clutch is let out. but you say there is no whinning when you are not moving with the clutch out??? might be the input shaft bearing which would suck.
His noise goes away when the clutch is in.
Everything you ever wanted to know about simple clutch opperation!
http://www.edmunds.com/ownership/tec...7/article.html
it is possable that it is something else. However isb would be my first thought. It would make sence that it is only doing it under load if it has just started to go out. I would bet that the longer it goes the louder it will get
