another fuel pump thread....car boggs when it has >a quarter tank
my 92 eg consistentley boggs when i have less than a quarter of a tank...usually i am on the freeway and somehow manage to LIMP it to a nearby gas station. why is it doing this, i have searched and i am still not sure if this was a symptom?
Re: (Throwdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown »</TD></TR><TR><TD CLASS="quote">could be a sending unit problem</TD></TR></TABLE>
can u explain this?
can u explain this?
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">ur an idiot im sorry........ ^^^</TD></TR></TABLE>
Yes, follow your less than 6th grade adequate knowledge base and believe < is a greater than sign and > is a less than sign.
Or the fact that you passively declare so much that it's NOT under ANY conditions your fuel pump.
Location: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
1 Post
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>^^^ no dumbass syndacate knows his **** ...he could very possibly be right i was going with the sending unit seeing how it seems to be running out at a quarter seen this before
Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">><><>>>>< << it doesnt matter which way there pointed.</TD></TR></TABLE>
That wasn't my main point, but it does matter.
My main point was simply that it sounds like your fuel pump, that's where I'd place my money.
If you want to listen to me and temporarily swap it with a known working one to see what happens, go for it, if you want to label me as an "idiot" and not touch the fuel pump, fine again, I still sleep at night.
I was trying to help you, both with your car problem and your math problem.
Re: (Throwdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1069694 sending unit </TD></TR></TABLE>
I might be missing something but the guy in the thread seems to have a car that's working fine and a gas gauge that's stuck.
The OP seems to have a car that's bogging out.
Either way, I got work to do, I'm out, my suggestion of "fuel pump" stays...good luck fixing it.
1 Post
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">my 92 eg consistentley boggs when i have less than a quarter of a tank...usually i am on the freeway and somehow manage to LIMP it to a nearby gas station. </TD></TR></TABLE> correct me if i'm wrong but if he is limping into a gas station with less then a quarter then maybe its really not at that level and basically empty, thats why i suggested the sending unit but i'm both maybe sending unit maybe pump
alright well thanks for you're input... i do not think it is the sending unit as well.
EDIT: actually it might be, im going to look more into the sending unit, bc that would make sense.
Modified by allricedout at 6:04 PM 1/21/2007
