Another EK Brake Master Cylinder Upgrade
I have a JDM 1998 Civic VTI - (LHD - B16a - ABS - 260mm Font Brakes) which comes stock with a 15/16th MC.
Since I have upgraded my front calipers to Wilwood DPHA 4 piston calipers and braided lines all around my brake pedal travel is way to long, even under hard braking pressure the pedal goes almost to floor and i can barely lock the wheels or actuate the abs. I am looking to upgrade the Master Cylinder and considering which options do I have in order to keep everything else the same? Apparently for what I found on the forum if I upgrade to a ITR MC I also have to upgrade the booster, is that really needed or I have any other option to just upgrade the MC? Should I consider a Nissin/OEM one or does Wilwood makes any decent bolt-on replacement? Thanks for the feedback as usual |
Re: Another EK Brake Master Cylinder Upgrade
I’ve got an ITR MC on my 2000 EK with OEM booster.
I got a super ITR MC on my LX booster
Originally Posted by tony_2018
(Post 51919923)
Originally Posted by Freedo_Civegra
(Post 51919920)
Does anyone know the P/N of that one? I assume it is an usdm ITR we are talking about |
On the eg civics yes, a line had to be re-bent or a new one had to be made. On the ek it was str8 bolt on.
(Post 51919950)
Originally Posted by creizlein
(Post 51919944)
and which size is that one? 1" ? did you had to modify any lines for it to fit?
Does anyone know the P/N of that one? I assume it is an usdm ITR we are talking about no modification USDM ITR mine is Centric |
(Post 51920015)
1”
Mine is the 13040033.
