Another car wont start thread.
The other day I was driving with my girl for around a hour or so when we decided to pull over into a parking lot so she could learn how to a manual car (seriously). So I let her drive around for about 15 mins and she only stalled out once. We pulled under a light so I could check the oil and I shut off the car. When I went to crank it back up it didnt go. I took it to an autoparts store to see if it was the one of the usual suspects (Starter, Alternator, Battery). And all came out in working condition. I checked all the fuses and for power everywhere even the hot lead to the starter and that checked out fine from there I checked all the grounds and made sure that they were all clean and scratched to get good contact. I tried the ignition and that was also good. From there I checked to see if I heard the main relay click and it did. Ive tried everything I knew so now I leave it up to my fellow H-T'ers for help.
Thanks in advance (anything stupid keep it for a yard sale),
-Jeff.
-Jeff.
Re: Another car wont start thread. (DelSolMarine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMarine »</TD></TR><TR><TD CLASS="quote">who checked the starter? sounds like a starter 2 me what kinda test did they do 2 ur starter??</TD></TR></TABLE>
I took out the starter and had it tested by o'reilly's, it turned over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej1_lsvtec »</TD></TR><TR><TD CLASS="quote">check the timing belt my friend had the same problem and it turned out to be a riped timing belt</TD></TR></TABLE>
How could it be the timing belt when the bottom end doesnt even turn over?
Re: Another car wont start thread. (twelvesorbetter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twelvesorbetter »</TD></TR><TR><TD CLASS="quote">obvious things? crud on the battery? loose connection? any type of bad connection is going to cause that symptom..</TD></TR></TABLE>
No sir.
No sir.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMarine »</TD></TR><TR><TD CLASS="quote">ej1 made a good point... check the timing belt... or tow it 2 a shop just not a meineke lol </TD></TR></TABLE>
How could it be the timing belt when the bottom end doesnt even turn over? And forgive me Im not a "send to shop" type of guy.
Unceasing Measure
Re: Another car wont start thread. (Falkien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">that's what you get for letting a girl drive your car . seriously though, have you checked your grounds? </TD></TR></TABLE>
Grounds don't fall off when you're driving. If he had done a swap this would be a likely candidate, but after drving for 15 minutes - regardless of how jerky the launches - a ground isn't going to suddenly come undone.
Also, he spoke to this in his first post. Why don't you reread it and not ask questions that have already been answered, hmmmm?
As to the OP, if it's not cranking and the starter is functional, you either have a loose connection somewhere or a significant loss of battery power. Try jump-starting it even though your battery tested "fine". Try popping the clutch - push starting - and see if that gets the car moving. It could just be a silly one-time deal.
Re: Another car wont start thread. (Archidictus)
I can push start it. I do think that the grounding in the culprit. Ill let you guys know after this weekend. Once again thats for the help.
A list of possibilities:
Battery Terminal connections loose or corroded
Battery discharged or faulty
Clutch not completely depressed
Broken, loose or disconnected wiring in the starting circuit
Starter motor pinion jammed in flywheel ring gear
Starter solenoid faulty
Starter Motor faulty
Ignition switch faulty
Starter pinion or flywheel teeth worn or broken
about all i can think of, good luck
i had a problem similar like that before, and found out it was my distributor, i took the spark plug out and tested it on top of the motor, there was a spark but i guess the spark wasnt powerful enough to shoot off the first piston, so i got a new distributor and it fixed it (i also put new spark plugs). hope this helps.
Stunna MIKE
01-19-2011 07:08 PM
em1gangsta
06-29-2008 01:29 PM
