Another brake swap
Another brake swap
https://honda-tech.com/zerothread?id=2025500 i am wondering if the bushings in the trailing arm are replaceable in the si diagram its like the 16th post down. (im talking about the bushing mount that is right above the #20 bolt) My guss is that if they are you have to press them out and if so how would you make sure that they are gonna line up when you put them in
Re: Another brake swap (highlandparkbigpimpn)
Yes they are replaceable. You can burn or press the old ones out but you have to press the new ones in. If you use the energy suspension replacement I recommend you burn your old bushing out so you can get that pin from the old one and put it into the new one. The OEM replacement has it in it. PM me if you have anymore questions.
-Jeff.
-Jeff.
Re: Another brake swap (American.Graffiti)
ok i found a replacement bushing from energy suspension but were can i find the middle peace that boltz to the car, i would say use the old 1 but the bushing dosent look like it will fight right.
GaP.OBED
Suspension & Brakes
11
09-11-2012 06:42 AM
madmanmaigret
13
08-01-2007 05:09 PM
