another autolock question!!
Old 01-13-2004, 08:46 AM
Jon D's Avatar
Default another autolock question!!
I dont drive my si all that much so i have only used the autolock a couple times. My question for you guys is the fitting. Everytime i use mine it doesnt seem to fit the clutch pedal the whole way. I wish i could show you all what i mean but perhaps some of you have the same problem and know what i am talking about. Its effective but its like i cant pull the handle up very far, and when you look down you can see that it doesnt close the whole way but enough that it will not come off. Is there something i am doing wrong or do you all experience the same thing when putting yours on? Any suggestions as to what i might be doing wrong. Its such a tight area to menuever and its been so cold that when i have put it on i just make sure and wont come off and leave.
Old 01-13-2004, 09:11 AM
Jon D's Avatar
Default Re: another autolock question!! (jh4dc23spoon)
This forum is moving pretty quick today so ill give a bump...i know you guys will not what to do or have suggestions.
Old 01-13-2004, 11:23 AM
underpressure02's Avatar
i know on my 92 hatch I had to put it up high on the back of the floor board if that makes any sence and the bottom of the autolock kind of sat at an angle on the floor. I was able to pull the handle up pretty far.
Old 01-13-2004, 11:27 AM
TSPeed Factory
AzntaggeR's Avatar
Default Re: another autolock question!! (underpressure02)
yeah i had the same problem when i first got my autolock. i've noticed if you put it on higher up on the clutch pedal it works better.
Old 01-13-2004, 11:33 AM
Mrfeee1's Avatar
I'd be interested to hear what poeple got to say, i have a smilar problem my lock sits sorta sideways and i pull up real hard till i hear that last click. sometime i feel like im doing something bad to the clutch pedal, but its worked so far no problems.
Old 01-13-2004, 12:19 PM
Jon D's Avatar
Default Re: another autolock question!! (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">yeah i had the same problem when i first got my autolock. i've noticed if you put it on higher up on the clutch pedal it works better.</TD></TR></TABLE>
Thanks i will have to try that the next time i use it. It just doesnt seem to slide the whole way up when you use it towards the bottom of the clutch pedal for some reason. Anybody else out there run into problems using there autolock?
Old 01-13-2004, 12:41 PM
NiiS's Avatar
I used the brake for autolock while having a clutch pedal kill switch. I also removed the ECU but that`s another topic alltogether.
Old 01-13-2004, 01:00 PM
Thirty-Nine's Avatar
Default Re: another autolock question!! (Sin 2)
I use my Autolock religiously. It was hard to put on at first - I even considered returning it. However, the trick is to tilt it a bit so it fits correctly. It might take some time to figure it out (and I suggest doing it in the daylight so you can see what the hell you're doing) but it will fit.
Old 01-14-2004, 04:06 AM
Jon D's Avatar
Default Re: another autolock question!! (Sushiboy)
Thanks guys........i knew i wasnt the only one with this damn problem. I will have to play around with it this weekend when i have some daylight!!!!!!
Old 01-14-2004, 05:23 AM
The Internet Tough Guy's Avatar
yeah i bought one for my 96 ex.. i spend about 20 minutes in pep boys parking lot trying to get the damn thing to fit right. i got so pissed and just took it back.
the next day i went with a better method of theft deterrent... mwahhahaha
Old 01-14-2004, 03:53 PM
JDMTurboEG6's Avatar
yea when i got mine i used to hate it. was a real pain to get it on but it works really well once you get used to it.
Old 01-14-2004, 03:54 PM
Risky Business
BauleyCivic's Avatar
Default Re: another autolock question!! (JDMTurboEG6)
No dead pedal = No problems
And i bought one for my brothers 99 EX and it works fine
Old 01-14-2004, 04:10 PM
Kid1320's Avatar
Default Re: another autolock question!! (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">No dead pedal = No problems
And i bought one for my brothers 99 EX and it works fine </TD></TR></TABLE>
yup. my friend with a 99-00 si removed his dead pedal and it works fine. the sorry thing is that you dont have the dead pedal anymore
INVALID
Honda S2000
09-05-2009 10:52 AM
92DaIntegra
06-13-2008 06:49 PM
stealthcrx
06-20-2007 11:59 AM
mrnewguy
08-15-2006 05:15 PM
spiceisler
13
07-02-2002 10:34 AM
Quick Reply: another autolock question!!
