Am I the only one with low washer nozzle pressure?
Old 01-27-2003, 08:08 AM
pogichinkyguy's Avatar
Default Am I the only one with low washer nozzle pressure?
I've got a 99 Civic Coupe... and the pressure of the washer nozzles suck...does anyone know how to fix this?
I'm driving and cant wash the windshield coz the fluid just sprinkles the bottom of the windshield and I have to keep spraying till the wipers get wet enough to clean the bottom anyone have the same issue?
Old 01-27-2003, 09:12 AM
viCeVerSa's Avatar
Default Re: Am I the only one with low washer nozzle pressure? (pogi*****yguy)
ehhh...... ill be the first one to ask, are you out of windshield washer fluid?
Old 01-27-2003, 09:43 AM
MilanoRex's Avatar
Default Re: Am I the only one with low washer nozzle pressure? (viCeVerSa)
maybe they're dirty... try sticking a needle in it.
Old 01-27-2003, 09:59 AM
racecarpete's Avatar
Default Re: Am I the only one with low washer nozzle pressure? (MilanoRex)
this is my guess. and while you are at it you might need to aim them.
Old 01-27-2003, 10:03 AM
Default Re: Am I the only one with low washer nozzle pressure? (SilverCivic2k)
I have done all of those, is there a motor or something I can replace?
Hehe... maybe like a mod of some type to get it to spray stronger...hehehe
Old 01-27-2003, 10:19 AM
Pengo's Avatar
nozzles not even hooked up in my car cuz i never use em, but if you can somehow make the holes in the nozzle smaller or get ones that are smaller than what you have rite now (no LEDs please), then you will probably get a stronger spray without having to change anything else.
Old 02-10-2003, 09:51 AM
shipsaeki's Avatar
Default Re: Am I the only one with low washer nozzle pressure? (Pengo)
just replace the pump to a stronger one. only cost you like 40 bucks... mine cost like 80 cause its a dual pump for the front and back windows
Old 02-10-2003, 11:18 AM
In The Garage
Shawn C's Avatar
Default Re: Am I the only one with low washer nozzle pressure? (shipsaeki)
pull the line off of the nozzle and see if it has pressure then, if it does just get some new nozzles, just make sure they dont light up.... if it doesn't, get a new pump or just carry a squeegie around with you
regnevazota
12-29-2012 04:50 PM
TonyRomo
06-05-2011 07:21 PM
EF9_TryMe
08-11-2010 09:26 PM
Kp_VtekNiks
10
12-01-2004 05:15 PM
Quick Reply: Am I the only one with low washer nozzle pressure?
