Am i choosing the correct camber kit for this swap?
Currently i have the stock rear drum brakes. However I am buying some a camber kit for the rear and fronts. I was wondering are the camber kits the same for stock civic susepnsion and gsr brake suspensions that most people swap in? If they are not I want to get the camber kit that will work with the gsr swapped brakes so please help me out. I need to know asap
Re: Am i choosing the correct camber kit for this swap? (95 RED CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 RED CIVIC »</TD></TR><TR><TD CLASS="quote">just go skunk 2</TD></TR></TABLE>
good job not answering his question...
the rears i believe are the same across the DC/EG/EK's. the cheap alternative is getting washers and some longer bolts and just shimming where the rear upper arm bolts to the body to bring the camber back out. make sure you use high grade bolts and washers.
the fronts are going to depend on what kit you get. if you get an adjustable ball joint, they may be the same for all chassis, but i'm not sure, check with the manufacturer. if it's an entire front upper arm, get the one ment for your car, a 96 civic. the integra arms are different and won't bolt into your wheel well.
long story short, get the kits for your car, they should all work for integra brakes.
1 Post
Re: Am i choosing the correct camber kit for this swap? (mdd)
92-95 eg and 94-01 integra camber kits for the front are the exact same....for the 96 hx, you might want to get the normal 96-00 front camber
drewbie
13
01-06-2005 03:13 PM
