LS/VTEC Swap
Old 12-30-2006, 01:27 PM
3Rd GeAr PuLl's Avatar
Default LS/VTEC Swap
I have a ls/vtec long block with everything and a lsd tranny bolted onto it.
I have axles, mounts, ecu, and obd1 jumper harness. is there anything else i need to complete this swap into an 96 ek .
And i was wondwering if i could use my stcok d series linkages to use in the swap and also do i habe to have a vtec wiring harness or can i just wire in vtec
Old 12-30-2006, 01:46 PM
pdiggitydogg's Avatar
As long as you have the "correct" mounts/brackets (em1)...
You need b series linkage.
You can wire in vtec OR swap in a harness - your choice. Search for how to wire vtec.
91 DA B18B1
03-25-2011 08:15 AM
GSR936
02-18-2010 05:55 AM
rollintegra
12-10-2008 10:55 AM
ungers_21
06-16-2008 05:02 PM
zx2gotboost
03-02-2006 03:36 PM
Quick Reply: LS/VTEC Swap
