already searched....rear swaybar on EG hatch?
I am wanting to put a rear swaybar on my 93 Si Hatch.
I had a 00Si before that I upgraded the rear swaybar so i still have it kicking around. I even have the rear lca's from it too.
so will the lca's from the 00Si fit my 93?
also, will the rear suspension still fit?, cuz from my understanding the eg has a thicker lca than the ek. so i'm thinking the "fork" on the shock will be too large if i swap the lca.
also, what bolts could i use to mount the swaybar on the subframe? I have all the brackets still, i just need i guess 4 bolts and 4 nuts cuz unlike the EK Si, my eg doesn't have the 4 nuts welded behind the subframe.
thanks in advance for the help
i dont know about the rear suspension but i know the sway bar from the em1 will fit your hatch but from what ive heard you either need aftermarket lca's or you need to use some sort of spacers in between the forks for the strut and the lca for the em1 lca's to work.
.ShawnD.
06-16-2006 12:20 AM
impound
12-22-2004 03:36 AM
Chugger
03-20-2002 12:59 PM
