Almost done with 5 lug on my EM1......1/8 MC good or do I need the 1in?
Almost done with 5 lug on my EM1......7/8 MC good or do I need the 1in?
Just as the title says, I just realized that I dont have the 1in master in my 00 EM1. Any major issues with this and having a OEM calipers? I mean I can get a bigger one eventually but is there any true detriment running the 7/8 as opposed to the 1in?
Modified by 1337 Si at 10:49 AM 7/29/2006
Re: Almost done with 5 lug on my EM1......1/8 MC good or do I need the 1in? (1337 Si)
I'm using my stock MC on 98hb.its been fine for now and its been 10 months.so I think u should be fine with ur stock one.
Re: Almost done with 5 lug on my EM1......1/8 MC good or do I need the 1in? (JDM-EJ698)
I mean I might eventually go with the 1in but as of now will the 7.8 be cool?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ698 »</TD></TR><TR><TD CLASS="quote">I'm using my stock MC on 98hb.its been fine for now and its been 10 months.so I think u should be fine with ur stock one.</TD></TR></TABLE>
be professional
Re: Almost done with 5 lug on my EM1......7/8 MC good or do I need the 1in? (1337 Si)
The 7/8" MC was barely enough for the 10.3" fronts, IMHO. I've owned 2 Civics with 10.3" fronts and 7/8" master cylinders, and the pedal feel was just acceptable (I prefer a firm, short pedal). Since you're swapping to 11.1" fronts with the larger 17CL15VN calipers, I would suggest upgrading to a 15/16" or 1" master cylinder to maintain a pedal feel similar to stock. All of the cars with 17CL15VN calipers from the factory were also equipped with a 1" master cylinder by Honda AFAIK.
If you want a slightly longer pedal than stock to aid in modulation (since you don't have ABS), keep your 7/8" piece.
Re: Almost done with 5 lug on my EM1......7/8 MC good or do I need the 1in? (Targa250R)
VEry interesting, and it does make sense that having more pedal to play with would be better for modulation. My question though is how soft will it really be? Another thing, don't the 92 Accord wagons have a 1 1/8in master?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1337 Si »</TD></TR><TR><TD CLASS="quote">VEry interesting, and it does make sense that having more pedal to play with would be better for modulation. My question though is how soft will it really be? Another thing, don't the 92 Accord wagons have a 1 1/8in master?</TD></TR></TABLE>
I'm running Integra fronts with a 13/15" MC, and it acceptable, but also soft. I plan to get a 15/16" MC as soon as I get money.
98+ 1" Integra MC will bolt up to the Si BB. You won't have to bend lines either.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1337 Si »</TD></TR><TR><TD CLASS="quote">My question though is how soft will it really be?</TD></TR></TABLE>
It's not going to be mush-city provided that the system is bled thoroughly, but it will be longer than your current pedal travel. If you are unsatisfied with your current pedal feel, you'll definitely want to upgrade the MC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Another thing, don't the 92 Accord wagons have a 1 1/8in master?</TD></TR></TABLE>
I'm not sure. I'll have to take a peek next time a CB9 comes into the junkyard. It won't bolt up to your booster though, and will require some hard line fabrication.
So think of it like a stock clutch as opposed to a HD pressure plate. As long as all the braking is still there and I get more variablity in the pedal that might not be so bad. What do the new 1in MC go forthrough Honda?
I have probably done a combination of almost all the boosters/mc that fit in the ek. The stock master will work, the pedal will just be a little lower than stock. A 98+ teg mc will fit your stock booster and you will regain all of the lost travel, however I have noticed that on teg brakes with the stock booster and 1" mc the booster will run out of travel. You may not run into that problem with the 11" brakes though. I say don't worry about the mc until after you try it out. If you want the pedal higher buy the 1"er
alltech_hybrid
Texas -OK -LA (Sales)
03-17-2006 08:53 AM
