are all oem civic shifters the same?
i just got an auto-manual swap, and the shifter that was said to be oem is banging on my exhaust pipe pretty bad
are all civic shifters the same? interchangable? i think i'm going to go to honda tomm and just fork over the 30 bucks for a brand new specific oem one just to be sure.
also if you could point me out to a good DIY on the shifter install it'd be greatly appreciated
1 Post
Re: are all oem civic shifters the same? (mr poo)
All i know is a d-series are the same... b-series are the same.. but I think the only difference between the two are how thick the bottom of the shifter is, (where the bolt goes through with the shiftlinkage
https://honda-tech.com/zerothread?id=1007935
Diff shifter but I'm sure a very similar procedure
1 Post
Re: are all oem civic shifters the same? (99FBPSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99FBPSi »</TD></TR><TR><TD CLASS="quote">I had a 99 si shifter and when I took off my 94 civic shifter everything looked the same. </TD></TR></TABLE>
The GSR dual bend shifter I have in my car was longer at where the shifter connects to the linkage and wouldn't slip into the d-series linkage.. so I have to cut it shorter to fit.
EG-SIXV-TEC
10-09-2011 07:06 PM
