? for all '99 civic dx's
Does anyone know where to adjust ur idle on the '99 civic dx?? i know its near the throttle body, but i can't find that lil screw. any available pix is good. Peace
Re: ? for all '99 civic dx's (B18C_DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_DC2 »</TD></TR><TR><TD CLASS="quote">why do you need to adjust your idle</TD></TR></TABLE>
b/c my idle is bad and just wanted to see what difference would it make.
Re: ? for all '99 civic dx's (delslo26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo26 »</TD></TR><TR><TD CLASS="quote">*!WACK!* (as I smack your hand) Don't touch That! </TD></TR></TABLE>.......why not, something bad is gonna happen???
There is a screw (usually covered with a little plug [as stated above]) on the top of the throttle body.
The reason that you were asked why you need to adjust this screw is because this is usually not the first course of action when fixing an idle problem.
It would be easier to help you diagnose the idle problem if we knew what changes were made to your car that caused the problem in the first place.
Re: ? for all '99 civic dx's (ek9 ferio)
There are two screws that have an effect on idle rpm. They are the Throttle Stop Screw (TSS) and Idle Air Bypass Screw (IABS).
The TSS is set by the factory and has a direct effect on the TPS sensor output, as they are mounted on the same shaft. So messing with this screw is never advisable.
The IABS is used to adjust the amount of air that is bypassed around the throttle blade. With a 99 Dx, since it uses a 3-wire IACV, the procedure for setting the idle is different than with a 2-wire style. When setting the idle, for a 3-wire IACV, you do NOT disconnect the IACV connector.
But if all of a sudden you have idling problems, you may want to inspect other things first. What does the maintenance history look like: air filter, cap, rotor, wires, plugs, PCV, valve adjustment.....the basic maintenance items will degrade over time and can affect your idle, even a lazy O2 sensor will have an affect.
FYI: The Helms manual (link in my sig) has all this information, and more....it might help to have one.
hatchfreak92
10-17-2004 08:59 PM
JCCOOL43
06-13-2003 03:15 AM
niedejb
02-13-2003 01:47 PM
