Alarm install help, car just tried to start by itself. PLEASE HELP
Oh my, I'm so scared and confused right now...
I don't have a cam now, I'll try to get one in an hour or so but I'll just post like this for now.
I'll post everythign I did from the beginning okay.
I hvae a compustar CM1000A alarm. Basic unit but I basically got it for remote door lock/unlock cause it's annoying to use the key. ANyways:
I disconnected the negative battery terminal before I began.
THe first connector basically has 4 wires: Red (Constant 12V), Purple (Parking lights), Black (ground), and Grey (trunk).
I went by this: http://www.commandocaralarms.c...Civic
So, I spliced in the red wire to the white wire in the ignition harness.
THen, I found a ground.
Then, I spliced in the purple wire to the red/black wire in the green plug.
I couldn't find the trunk output and I don't really care about that so I just left it unconnected.
I put in the LED in to the car.
So, now, I figured, why not try to test what I have so far? I didn't connect the door locks or siren or anything but according to my logic, if I have the power stuff plugged in and the LED light plugged in then I can
a) see if the LED is working as it should flash when it's armed
b) see if the parking lights flash when I lock/unlock the doors
So... I went and plugged in the negative terminal on the battery...I didn't tighten it down as I was just putting it back on for a minute to see how its going... and before I could mess with anything (maybe 30 seconds after I put the terminal back on) my car tried to start!!!!! It was in first and handbrake was on so it just moved forward a tad (luckily it didn't hit my other car parked in front of it).....then before I could realize what was happening like 10 seconds later it did it again!!! So I ran and disconnected my negative terminal (thankfully I didnt tighten it so I jsut pulled it off) and here I am.
Can someone tell me what's going on? I will get pics to help diagnose but from what I wrote does anything seem wrong? I'm REALLY surprised because my car doesn't start unless I have teh clutch pushed in when I use the key so how would it bypass that somehow and just try to start now??
Thanks!
Oh it's a 92 4 door.
Thanks!
Re: Alarm install help, car just tried to start by itself. PLEASE HELP (BlitzSix)
I'm an idiot, I didn't see the security section, can a mod move it ?
Thanks.
Thanks.
Double check your wire schematic and make sure all your wires are hooked up right.
I had installed a remote starter security system in my Teg a while back. works great for except when the car is in gear.
Had it take off on my *** a few times. Decided it wasn't cool to have a remote starter for manual trans.
I'm pretty sure you have some wires mixed up. What i would do is question the wires that your not to sure of.
Ground those wires and see what they do. These alarm systems work on the negative.
Re: Alarm install help, car just tried to start by itself. PLEASE HELP (Kingfish714)
coppy past is the only way i no of
put that in nuetral from now on also incase it does start up again. im sure u already figured that out but just in case
Re: Alarm install help, car just tried to start by itself. PLEASE HELP (anavrin351)
Thanks guys.
MODS, I made antoehr same thread in the security section so lock this one if you aren't supposed tohave 2..
dohctor_B
Audio / Security / Video
07-29-2012 05:43 PM
BlitzSix
17
05-18-2007 09:25 AM
