Air Suspension?
Air Suspension?
I have a few Qs on this topic...
1) Does the constant ride height change mess the alignment up?
2) Would it matter if I had a camber kit all the way around?
Re: Air Suspension? (99D16VTECCivic)
Re: Air Suspension? (Hybrid95CivicEX)
yeah handling will suck, the guy in the new honda tuning with the del sol was bitching about how he wished he hadnt put it on, cause i doesnt handle for ****.
when you raise or lower it, sure it messes up alignment. you get it aligned at the height you would normally drive at on the highway and if you want to put it frame on the ground for show or just cruising around saturday night it wont mess up you tires as much as you would think. just get it aligned at the height you like and then you can out her up or down as you like as long as you put it back at the pressure you aligned it at for most of the time.
