Air Conditioning Compatibility DC<>EG??
Re: Air Conditioning Compatibility DC<>EG?? (CXHatchback)
what part are you exactly trying to use.. the whole entire thing?... such as compessor,lines, bracket, condensor? also some compressor uses certain refrigerant... like the new integs used r34 or some **** like that.. not the same as the older ones
Re: Air Conditioning Compatibility DC<>EG?? (311)
if they are both R134, then the fittings should be the same....if one is R12, and the other is R134, you might have to find special fittings to convert the R12 to 134 and go from there.....the R134 conversion should cost no more than $50 with gas
Re: Air Conditioning Compatibility DC<>EG?? (SpoonFedHatch)
Yeah but R134 is too high pressure, so it's not gonna last long with that system. Converting back to R12 would be the way to go.
I was just wondering about the compresor, if they're interchangeable.
Re: Air Conditioning Compatibility DC<>EG?? (b16matt)
who needs ac?
Yep, I finally broke one of the two bolts holding mine on, so I had to take the belt off to make sure I don't brake the last one. It is too damn hot with the sun even in February. Gotta get that P54 bracket, NOW.
epingquian
04-03-2018 07:56 PM
Dekorum
19
08-01-2010 04:04 PM
