Are the aftermarket oil pans worth it?
Old 09-21-2001, 09:12 AM
SoloSol's Avatar
Default Are the aftermarket oil pans worth it?
I think I blew a motor because of oil starvation. I use the car for aggressive street driving, occasional auto-x and a few track days. I would appreciate any thought and comments. The car is a 93 delsol sohc VTEC. 100k+ mi.
Old 09-21-2001, 09:34 AM
MrDX's Avatar
Default Re: Are the aftermarket oil pans worth it? (SoloSol)
Moroso makes a pan with an optional splash sheild to make sure to avoid just that. It makes it a 5.5 quart oil system, but it does the job.
Old 09-21-2001, 11:39 AM
3.3.3's Avatar
Default Re: Are the aftermarket oil pans worth it? (MiGs)
try the spoon pan....shweeeeeeet
Old 09-21-2001, 11:41 AM
Chris93Si's Avatar
Default Re: Are the aftermarket oil pans worth it? (spnhb)
I don't think Spoon makes a SOHC oil pan.
Old 09-21-2001, 03:02 PM
DragII's Avatar
Default Re: Are the aftermarket oil pans worth it? (Chris93Si)
no, they are not worth it. try keeping your oil level in the normal range before raggin it out
Old 09-24-2001, 10:04 AM
advanracing62's Avatar
Default Re: Are the aftermarket oil pans worth it? (DragIIcivic)
I want to get an aftermarked oil pan but I think I'll run into problems cause I had to bang my pan in a bit to get the header to clear. Anyone know if you can run JDM header with the aftermarkets?
Old 09-24-2001, 10:23 AM
BakedCookies's Avatar
Default Re: Are the aftermarket oil pans worth it? (advanracing62)
Yes, I am running JDM 4-1 with heat shields with a moroso aluminum pan, no fitment problems at all, Also almost 6 quarts of oil in my motor makes me warm and fuzzy inside.
Old 09-24-2001, 12:28 PM
3.3.3's Avatar
Default Re: Are the aftermarket oil pans worth it? (BakedCookies)
well, the purpose of aftermarket oil pand is either for more oil volume, or to prevent the oil from splashing around under hard circuit conditions. they are also run the oil a little cooler because of the design.
Old 09-24-2001, 12:41 PM
maxim's Avatar
Moroso makes an excellent product. It actually comes with a fitting to accomodate for a turbo feed line or a to fit an oil reading unit. (TMS.TX, Bryan CS)
For turbo a application(Drag specifically), so you wouldn't have to weld the oil pipe on there to attach to the oil feed line - is that true?
Old 09-24-2001, 01:58 PM
DragII's Avatar
Default Re: Are the aftermarket oil pans worth it? (maxim_force)
true, but it only cost me $20 to get the fitting welded, it costs like $400 to get the morrosso, you decide what the best bargain is
Old 09-24-2001, 02:12 PM
maxim's Avatar
Yeah, I was just wondering...I had thought about getting a moroso just to have one for turbo and then putting the stock back on if I planned on selling the car w/o the turbo. I will probably just go to my local dealer and just get an OEM for about 30-40 bucks(I think that's what it will cost).
Old 09-24-2001, 03:11 PM
DragII's Avatar
or a junk yard
Old 09-24-2001, 04:08 PM
maxim's Avatar
Oh, I didn't even think about that, thanks for the idea
Old 09-26-2001, 08:37 AM
brcivic411's Avatar
The real purpose for a turbo car is the fact that you increase your oil capacity. for the 1000th time, oil is the lifeblood of your engine, and your turbo.
for me, it wasn't worth spending $400 on it although i definitely would if i had the cash. I just went ahead and got a B&M oil cooler for $100. It slightly increases oil capacity AND cools the oil.
you can also look into getting remote oil filter mount and use a LARGER filter. LIke one of those NASCAR ones that are 3x larger than honda stock.
integrawow
Suspension & Brakes
12-23-2009 08:23 AM
miataguy
11
02-20-2007 05:00 PM
cyrix12
03-06-2006 10:30 PM
fastest
05-19-2004 08:20 PM
Projekt20
09-09-2002 10:09 PM
Quick Reply: Are the aftermarket oil pans worth it?
